2014/05/31
Somebody ask me to tweak its Arnova 8b G2 (not 8G2), in order to add Google play. The tablet arrived stock, and I restore factory setting on it.
I tried Arctools, but I never have been able to install anything.
I also tried to boot in recovery mode, but no combination of command works (reset +, reset pwr, pwr +)
For the moment I only have a tablet with gingerbread on it without google play.
If a 4.x rom could be upgraded I would be very interested.
See picture here after for details:
There is no 3.0.8+ kernel for that tab. Consequently no 4.x builds.
Maybe the firmware of the 8G2 works also on the tab. Difference only HDMI?
You will find both firmware here: http://arnovatech.com/support/updates_fwm.html?country=us&lang=en
2014/05/31
Initially I planed to use the following tutorial:
And flashing the following rom:
I am assuming that 8G2 and 8bG2 are the same except for physical buttons.
My concern is that I have not been able to boot in recovery mode, then RKBatchTool does not recognize the tablet... I saw that to boot on recovery on 8G2 is reset & pwr like it is shown on the following picture:
But it does not seems to work... (neither reset & + or pwr & +). I will try again now that the battery is full, it may help
To install the usb flash-driver pls use this tool: http://crewrktablets.arctablet.com/?wpfb_dl=1187
De-install the driver first.
2014/05/31
Email sent to archos support team in order to have the procedure to enter in recovery mode on the 8b G2.
I also try to install the firmware of the official web site, it's still a useless 2.3.1 gingerbread rom...
I hope I will be able to switch to ICS rom mentionned there:
Otherwise this tablet is just unusable...
Are there other keys?
Unplug the charger. Then try each of the three keys together with reset. Try also reset without any key.
Hm, do you hear a PC sound after pressing the buttons?
What windows version? Do you use an usb2.0 port?
69 Guest(s)
Devices in use: Desktop (63), Phone (6)
