Arnova 8 G2
darodi79
Belgium, Wallonia
2012/09/28 - 02:01
Almost the same situation as in this topic
http://www.arctablet.com/blog/forum/arnova-7-g2/arnova-7-g2-with-ics/
I've bought a new arnova 8g2 8Gb tablet for my father from a retail chain in Belgium. The device was sold with Android 4.0.3 out of the box.... same sticker on the box as post above. funny thing, the manual was not updated and explains how to use the tablet with android 2.3
So my questions are:
-Is there already a modified rom dump for this model?
-Should I try what Oream did when he was unsuccessful? (manually, arctools, ..)
-Could the same technique as the 7g2 be applied to create a modified dump?
-If so, I can provide a dump (as soon as I go see my father). Is the dump tutorial still also valid for this model?
Thanks in advance for your answers.
The following users say thank you to darodi79 for this useful post:
Thanks Received: 264
2012/09/28 - 02:15
yes, the tutorial is the same
as soon you provide a dump admin will cook a firmware for the tablet
darodi79
Belgium, Wallonia
2012/10/20 - 22:45
Presse-papier02.jpgImage Enlarger
Presse-papier01.jpgImage Enlarger
I think I'm stuck.
I'm unable to use 'su' and become root.
I'm not sure if step 6 worked.
A screenshot of SuperOneClick results is attached
In step 7, I get:
C:Usersaurelio>C:Androidandroid-sdkplatform-toolsadb devices
List of devices attached
A80HT0123456789A        device
C:Usersaurelio>cd C:Androidandroid-sdkPlatform-tools
C:Androidandroid-sdkplatform-tools>adb push C:rkdumprkdump /sdcard/
1835 KB/s (63916 bytes in 0.034s)
C:Androidandroid-sdkplatform-tools>adb shell
shell@android:/ $ su
su
/system/bin/sh: su: not found
127|shell@android:/ $
I'll try again with the linux tutorial and will let you know what happens.
sp_PlupAttachments Attachments
darodi79
Belgium, Wallonia
2012/10/25 - 23:01
I've just tried the linux method.
I try to put the device in flash mode pressing vol+ key and reset button with a paper clip.
The screen becomes black.
Is the flash mode active when it's black? Should I see something else?
When I run the perl script, I get:
darodi@ubuntu-pc:~/Rockchip_dump_Linux$ perl ./an10g2_dump.pl
./rkflashtool: 1: ./rkflashtool: : not found
./rkflashtool: 1: ./rkflashtool: ELF: not found
./rkflashtool: 1: ./rkflashtool: �: not found
./rkflashtool: 2: ./rkflashtool: '
followed by many other errors.
all resulting dumps are empty, their size is 0.
Any help?
Thanks.
Thanks Received: 3169
2012/10/25 - 23:04
Is your Linux a 32 bits system ?
darodi79
Belgium, Wallonia
2012/10/25 - 23:30
ok found it. I had 3 problems.
- My usb cable extension was interfering with the detection of the device (saw it in linusb and dmesg logs)
-I had to compile rkflashtool using gcc
-I had to use 'sudo' in ubuntu or I get permission denied on the device.
I now have those files :D
darodi@ubuntu-pc:~/Rockchip_dump_Linux/20121025_2320$ ls -al
total 1659004
drwxr-xr-x 2 root root 4096 oct. 25 23:23 .
drwxr-xr-x 8 delphine delphine 4096 oct. 25 23:20 ..
-rw-r--r-- 1 root root 503316480 oct. 25 23:21 backup.img
-rw-r--r-- 1 root root 16777216 oct. 25 23:20 boot.img
-rw-r--r-- 1 root root 121634816 oct. 25 23:22 cache.img
-rw-r--r-- 1 root root 8388608 oct. 25 23:20 kernel.img
-rw-r--r-- 1 root root 4194304 oct. 25 23:23 kpanic.img
-rw-r--r-- 1 root root 4194304 oct. 25 23:20 misc.img
-rw-r--r-- 1 root root 16384 oct. 25 23:20 p00
-rw-r--r-- 1 root root 16384 oct. 25 23:20 p20
-rw-r--r-- 1 root root 16384 oct. 25 23:20 p40
-rw-r--r-- 1 root root 16384 oct. 25 23:20 p60
-rw-r--r-- 1 root root 16384 oct. 25 23:20 p80
-rw-r--r-- 1 root root 4194304 oct. 25 23:20 parameter
-rw-r--r-- 1 root root 16777216 oct. 25 23:20 recovery.img
-rw-r--r-- 1 root root 482344960 oct. 25 23:24 system.img
-rw-r--r-- 1 root root 536870912 oct. 25 23:23 userdata.img
should I upload the files there?
http://www.arctablet.com/blog/at-upload/
darodi79
Belgium, Wallonia
2012/10/25 - 23:32
to answer your question:
$ uname -a
Linux ubuntu-pc 3.2.0-32-generic #51-Ubuntu SMP Wed Sep 26 21:32:50 UTC 2012 i686 i686 i386 GNU/Linux
32 bits system yes
is it a problem?
2012/10/25 - 23:36
Not a problem, I asked because the supplied binaries in our package are made for 64 bits systems. Glad you managed and recompiled them by yourself :)
I'll just need backup.img uploaded at the address you have.
Thank you Wink
darodi79
Belgium, Wallonia
2012/10/26 - 00:37
file uploaded, enjoy
arnova8G2I.tar.gz
2012/10/26 - 00:38
Got it thanks.
I'll first make sure it's working fine with older Arnova 8 G2, then I'll add Google Play Store.
It should be ready later tonight Wink
Morka
Lille
Forum Posts: 203
Thanks Received: 75
2012/10/26 - 00:50
+1 darodi79 thanks
as there is no link ?
finally a 3.0.8 kernel
2012/10/26 - 14:33
I have posted an Arnova 8 G2 ICS stock firmware image and custom firmware with Google Play and root based on darodi79's dump here:
http://www.arctablet.com/blog/featured/arnova-8g2-custom-firmware-upgrade-android-40-ics-google-play-root/
Forum post:
http://www.arctablet.com/blog/forum/arnova-8-g2/arnova-8-g2-custom-firmware-upgrade-to-android-4-0-ics-with-google-play-and-full-root/
Tested OK on an old Arnova 8 G2 capacitive, 8 GB storage.
95 Guest(s)
Devices in use: Desktop (83), Phone (9), Tablet (3)
mansour
napkiraly
ahmedsaad
tiagoz
celinedeuxsevres
15djamal15
Topics: 6015
Members: 260841
