Arnova 8 G2 USB keyboard
Related Tags
Pragjag
2012/01/05 - 23:35
I'm new to tablet computers and want to get a case with an integrated USB  keyboard for my new Arnova 8 G2. The only matches I can find have a standard USB lead on the keyboard; I can find adapters to connect to the micro USB port on the tablet, but the spec says that I need OTG function for this to work.
Doers anyone know if the Arnova 8 G2 has OTG? Thanks.
alex
Forum Posts: 252
2012/01/06 - 00:05
Im not sure on the otg but i have found somthing you might like
http://www.itabletpcshop.com/Tablet-PC-bags-iPad-bag-Gadgets/Android-Tablet-PC-8-inch-Case-Keyboard-Bags
Im not sure is itsmicro usbthough which puts you back to square one
Confused
Pragjag
2012/01/06 - 00:24
That looks very similar to the ones I have seen on eBay.co.uk (I'm in the UK), but thanks for the reply. Smile
alex
Forum Posts: 252
2012/01/06 - 00:58
Im not 100% admin might noe this but i should think it does as the older arnovas do even the 5" ones and as this is newer and a more of a tablet i would say it probably does especially as it only has micro usb it would be daft not too do some reaserch on the internet and thet are not expensive so if it dosent work it not a huge loss and you probably can return it
tonylee5566
2012/09/08 - 03:10
i get a 7 inch tablet case with keyboard from http://www.itabletpcshop.com :)
63 Guest(s)
Devices in use: Desktop (59), Phone (4)
atgyuric
BBonch
crispyduck00
asgard2701
Rob_nl
shadowlabs
Topics: 6028
Members: 261274
