Arnova 8 G2 receives CyanogenMod7 Android 2.3 Gingerbread with Market and Root (alpha 2 preview release)
Thanks Received: 3169
2012/01/27 - 18:42
Image Enlarger
CyanogenMod 7 (CM7) firmware port for Rockchip RK2918 based tablets is making progress.
Morka user on our forum is giving us a second alpha release of a CM7 custom firmware for the Arnova 8 G2. While most of the drivers (WIFI, sound, video) are now working, this update can still be considered as an early preview release.
Features
Compared to the default firmware from the manufacturer, this custom firmware brings you the latest Android Android 2.3.7 (Gingerbread) update to your Arnova 8 G2 tablet. Additionnaly, you get other interesting features such as:
- root access
- Android Market
Release notes
Release notes from the author (2012/01/26)
What's new:
Fixed wifi
Fixed sound
Fixed 3G (no 3G I could not test it)
Improved management of memory
Adding market
There still have improvements to make
Important:
This custom firmware has no firmware update facility. You won't be able to flash another firmware by copying an update.img file to the root of the device. You will have to use Rockchip Flashing Tool for ARNOVA G2 and RK2918 tablets to flash a new firmware, please make sure that you are able to use this flashing tool before flashing this custom firmware.
Arnova 8 G2 CM7 preview firmware download
Firmware download: CyanogenMod.7.for.ARNOVA.8G2.alpha.2.img
(rapidshare link)
This firmware is specific to the Arnova 8 G2 and should not be installed on other devices.
WE WILL NOT BE HELD RESPONSIBLE FOR ANY DAMAGE TO YOUR DEVICE.
THIS FIRMWARE UPDATE IS USED AT YOUR OWN RISK.
WE RECOMMEND TO FLASH THIS FIRMWARE ONLY IF YOU ARE ABLE TO RESCUE A BRICKED DEVICE USING ROCKCHIP FLASHING TOOL FOR ARNOVA G2 and RK2918 tablets.
Installation:
- Download the custom firmware (see download link above)
- Connect your Arnova 8 G2 to your computer thru USB cable
- Flash the firmware using Rockchip Flashing Tool for ARNOVA G2 and RK2918 tablets
Release information and version fingerprint
Image Enlarger Android version : 2.3.7
Please use our dedicated forum topic to comment about this firmware.
Once this firmware is stabilized,…
james
2012/01/27 - 22:50
This is very cool. I'm wondering how it diverges from the custom ROM Sowa released?
2012/01/28 - 12:57
If I remember right, Sowa firmware is based on the stock firmware with its own modifications.
This one is CM7 based.
james
2012/01/28 - 22:11
Thanks, I've only ever really 'dipped into' Android so not familiar with where the different ROMs relate and differ. Running this one anyway as I did run CM7 on a HTC Hero a good while back. So we'll see how my usage goes and if any interesting issues crop up.
2012/01/28 - 22:17
Feedback is welcome, don't hesitate to come back here and let us know how it works for you.
EdArch
2012/01/29 - 23:38
Hey,
The flash worked perfectly but...
My Arnova 8G2 has a resistive screen.
The screen is not responding; the calibration bulls eye can not be clicked.
But the back button works and when pressed; I'm presented with the following menu option:
Continuer Avec
- Assistant d-installation
- com.android.provision.DefaultActivity
But similar to the calibration screen; there's no response from the resistive screen.
So I can not choose an option.
Any ideas how to fix?
How to get the resistive screen to work?
james
2012/02/02 - 16:46
I've been running this for the past couple of days. Quick impressions: Installation is straightforward, no problems there. Takes awhile to boot first time which caused some uneasiness for a little while 🙂 Since installing I've just had one spontaneous reboot which is pretty good. No obvious reason why and no problems since. Everything is running smoothly enough, I get occasional lag from applications. But audio and wifi work without any problems. Browsing is snappy even on long pages scrolling remains smooth and fast.  Flash 11 doesn't play nice (it's Flash after all!) so I'm having a look at that - I discovered Log Collector today so it has been an opportunity to see why browsers crash in relation to Flash.
lohtse
Forum Posts: 157
2012/02/02 - 23:35
would like to give this a try but any links to current firmware so can go back if not happy???
Joe Black 33
2012/02/08 - 15:02
Hy. It work perfect on my ARNOVA 8 G2, except the audio, i can't listen music or the audio of the films, i can see the film with MX player bud i don't listen anything. The webcam don't works and finally the screen have flashes. Good job, but there are some things to do. Sorry by my english...
fasli
2012/02/11 - 11:52
Bonjour
I have same problem like joe Black 33
No audio and no webcam and the screen have flashes.
What can i do Thanks
2012/02/11 - 11:59
This CM7 firmware is in its early stage (alpha 2), it still contains some bugs, the screen, audio and webcam problems seems to be one of them. You'll probably need to wait for more stable update for better functionnality.
You can flash another custom firmware from here:
http://www.arctablet.com/blog/featured/arnova-8-g2-first-custom-firmware-android-market-root/
or restore the stock firmware from the manufacturer:
http://www.arctablet.com/assets/firmware/Arnova8G2/AN8G2_stock_update.zip
In all cases, you'll probably require to use the Rockchip flashing tool as there is no currently no recovery functions in this CM7 port:
fasli
2012/02/11 - 12:44
Chronology:
1. Root : AN8G2_full_crom_eu_m2s.zip. Good but icone battery status bar does not function.
2. Root: CyanogenMod7: No audio no camera, screen scintillates
3. Return towards: AN8G2 full crom have 32s : no audio, screen scintillates.
4. Return towards: AN8G2 Stock update: no audio and the screen scintillates
5 -Root still towards: CyanogenMod7: no audio no camera, screen scintillates
I think that the problem it is because I root since AN8G2 full crom have 32s directly towards CyanogenMod7
Thank you for your assistance
2012/02/11 - 12:48
Thanks for the details.
I'll have to rely on other Arnova 8G2 users feedback here, I'll investigate more if needed.
fasli
2012/02/11 - 16:28
Hello
I think that I lost the files which were in the hard disk of  the shelf at the time of the first root.
Will somebody be able to copy the files of the disc of his  shelf and to me to send them by mall?
Thank you very much
ARNOVA 8 G2 4 GO
Currently Online: inviner
121 Guest(s)
Devices in use: Desktop (99), Phone (19), Tablet (4)
inviner
offcrash
mrbit
LeonDCA
mrscharling
ebbi1978
Topics: 6030
Members: 261556
