[ ROM ] Arnova 8 G2 first custom firmware with Android Market and root
Thanks Received: 3169
2011/11/30 - 21:48
Sowa from archosfans.com has just made a first custom firmware available for the Arnova 8 G2. This custom firmware for the Arnova 8 G2 tablet, brings Android Market and root access to the device.
Firmware download
We have been informed that this firmware should work only on the Arnova 8 G2 8 Gb model,
if you have a 4 Gb storage model, please don't use these custom firmwares.
Full version: AN8G2_full_crom_eu_m2s.zip
Maintain all system applications, added applications Google, except for the map. Updated Market and ROOT.
Installed as a regular way (copying update.img in the bank vntrenney flash), and through RKBatchUpgrade v.1.4.1
Easy version: AN8G2_eazy_crom_eu_m2s.zip
Removed: telephony, living wallpaper, start-up wizard and other minor applications.
Present the updated Market and ROOT. Installation is similar to claim 1
This firmware is specific to the Arnova 8 G2 (8 Gb model) and should not be installed on other devices.
WE WILL NOT BE HELD RESPONSIBLE FOR ANY DAMAGE TO YOUR DEVICE.
THIS FIRMWARE UPDATE IS USED AT YOUR OWN RISK.
WE RECOMMEND TO FLASH THIS FIRMWARE ONLY IF YOU ARE ABLE TO RESCUE A BRICKED DEVICE USING ROCKCHIP FLASHING TOOLS.
Firmware update procedure:
  • Connect your device to the USB charging cable, fully charge it and leave the socket connected
  • Unzip the update.img file out of the zip archive
  • Copy the img file to the root of your device
  • Unmount USB on your device, it should give a prompt similar to this one:
  • Push the Install button and follow the update procedure
  • You can also refer to our flashing procedure page for more details.
  • The first boot after flashing may take some time (few minutes), please be patient.
  • This first part of the procedure is similar to the one on the Arnova 10, that you can see on this video:
    Restoring Arnova 8 G2 default firmware
    In case you don't like this firmware or if you just want to go back to…
    programmer_94
    2011/12/01 - 08:49
    That's cool ! How about Arnova 7 G2 🙁
    2011/12/01 - 09:01
    It's coming guys, we'll announce it when ready.
    Sowa
    Russia, Novorossiysk
    Forum Posts: 47
    Thanks Received: 5
    2011/12/01 - 20:44
    I try to do is just to test I can not.
    China phone: Star A5000 => Star N8000
    Tablets: Archos 7C HT - Android 2.2.1 my custom ROM => ARNOVA 8G2 8Gb capactive, s_MorkaMod JB 1.2
    2011/12/02 - 10:12
    Welcome onboard Sowa, good to have you around [Image Can Not Be Found]
    I can send you over the Arnova 7G2 firmware dump I am working on.
    We'll need somebody else for testing, as my Arnova 7G2 test device currently does no boot and my dump is refused by Rockchip 2918 flashing tools, I am waiting for the official Arnova firmware to recovery my device.
    Sowa
    Forum Posts: 47
    Thanks Received: 5
    2011/12/02 - 15:54
    Welcome.
    I'm sorry for my english - Google translator.
    Thank you. I really need a dump. With original ROM problem with unpacking.
    You can download it here http://www.megaupload.com/?d=FZFNP0U0 (found a reference in one of the forums). Perhaps someone from the owners to agree to test AN7G2 Custom ROM, or you relive your own. Waiting for a reference to the dump (update.img)
    fred61
    2011/12/02 - 17:39
    @admin what about arnova 8 rom? there are a lot of fans waiting since august (1st announced release day) for it and arnova 8 g2 rom is out after a few weeks ...
    rawsonboy
    2011/12/02 - 21:42
    Just installed the new firmware and Market continually crashes - it loads, I can search and then when I try to install anything it crashes
    Help !!!!
    2011/12/02 - 21:45
    You can try a Factory reset (in Privacy settings).
    If it does not help, try flashing again the firmware.
    The firmware author (Sowa) is around in this forum, he may be able to help you.
    In the worse case, you will need to flash back the stock firmware (link is in the blog article).
    rawsonboy
    2011/12/02 - 22:08
    Tried both suggestions, same result both times:
    The Application Market (process com.android.vending) has stopped unexpectedly.  Please try again.
    Sowa
    Forum Posts: 47
    Thanks Received: 5
    2011/12/03 - 10:33
    Updated Custom ROM for ARNOVA 8G2, now two versions: Full and Easy.
    Original post by ArchosFans Forum http://forum.archosfans.com/viewtopic.php?p=379128#p379128
    rawsonboy
    2011/12/06 - 01:42
    Tried both.  Same result both time – Market still crashes [Image Can Not Be Found]
    Sowa
    Forum Posts: 47
    Thanks Received: 5
    2011/12/06 - 06:54
    based on xda-developers :
    MARKET FIX:
    1. Setting- -> Manage Applications-- >All -- >Market (Clear Cache then 'Force Stop' --
    DO NOT clear data)
    2. Setting- -> Manage Applications-- >All -- >Google Services Framework (Clear data
    then 'Force Stop')
    3. REBOOT
    4. Launch Market
    Repeat steps 1-3
    rawsonboy
    2011/12/07 - 01:23
    Still no joy.  Thanks for your efforts Sowa but I think I'll be sending this back - the Amazon site said it had access to the Android Market and it does, via the cut-down app which is no good to me.
    pfalcao
    Almada, Portugal
    2011/12/10 - 15:43
    The apps shown on Google Market are quite limited.
    Sowa, maybe changing the ro.build.fingerprint property at /system/build.prop could help.
    Could you provide a better string? Right now we get:
    ro.build.fingerprint=rockchip/sdkDemo/sdkDemo:2.3.1/GINGERBREAD/eng.yc.20110903.152730:user/opinions-on-teclast-p90hdst-keys
    Currently Online: Scorp76
    77 Guest(s)
    Devices in use: Desktop (65), Phone (12), Tablet (1)
    painor
    izemnagh
    evas1on
    castel_010
    heniek405.hb
    danigm1100
    Topics: 6015
    Members: 260834
