New Arnova 7f G3 Android 4.1 JB test firmware based on OMA JB v1.2.2a
Thanks Received: 3177
2013/01/16 - 13:17
Try to flash again, be sure to use Restore button in Rockchip flasher.
Also use a good quality USB cable.
garsianu37
2013/01/16 - 14:04
Thx for  quickly answers admin !
1. - i use Restore button in Rockchip flasher
2.- i have change the USB cable ( i have 3, i test all of them)
  .. unfortunately same thing apear Frown
  THX AGAIN !!!
WP_000050.jpgImage Enlargertunately same thing apearFrown
2013/01/16 - 14:12
Can you try to flash again the JB firmware ? If you have a desktop PC, it's recommend to connect the USB cable to the ports on the back of the machine, not the ones in front; also try to avoid using USB 3.0 ports.
Maybe try on another PC if possible ?
That can be a failure of the NAND flash memory, which isn't good Confused
garsianu37
2013/01/16 - 14:29
Thx for help!
Yes ...I try to flash again the JB firmware with no luck !
Next step will be to try to another PC !
....and...IF will be the NAND flash memory, how bad is it?
Must change the SD card inside of tablet?
THX for help and support ADMIN !
2013/01/16 - 14:38
You may also try RK_Android_Tool (v1.35) from our Rockchip flasher page.
Once your device is detected (it works the same as Rockchip batch tool), just push the Erase IDB button, when erase is finished try again in Rockchip Batch tool.
I don't think you can repair a damaged NAND flash, you'll have to return/RMA your tablet to the manufacturer.
garsianu37
googlemd
2013/01/16 - 16:44
Do this l, it worked for me. Turn off the tablet. pres volume down then power button and keep pressed until screen is on. Then press first power button and volume up button above to enter recovery mode. then do a wipe clean or something like this(i dont remeber for sure. after that enter 4 and 5 points of menu shown there. it should work. I dont know if this helps but i putted the ics firmware on sd card. Try.
The following users say thank you to googlemd for this useful post:
garsianu37
googlemd
2013/01/16 - 16:49
and when its booting after reflash wait for more time to bot but up. or plug in the charger.
garsianu37
googlemd
2013/01/18 - 16:07
After some time of testing, my conclusions about this firmware is that it's better than ICS: faster, smoother, easiest. Only PROBLEM: tablet is booting only with charger in. I looked up on another topics and found same issue and fix for it: the idea is to change services.jar file in sistem/framework folder, with one given by a link. I did it and the booting was fixed, but tablet speed was slown down... And I came back to ICS.
Fixing this problem will make it perfect.
npd
2013/01/18 - 17:10
Hi, my device very quickly discharged battery. every minute by 1 percent, is this normal?
googlemd
2013/01/18 - 18:41
But after some time of staying, is the battery level increased again?
npd
2013/01/18 - 19:12
charges increased only when the tablet restart. 10-15 percent
2013/01/18 - 22:00
Thanks for the tip, I'll have a second look if I can make some improvements in the firmware.
googlemd
npd
2013/01/21 - 16:54
If the tablet is just sleeping for 10 hours consumes 10.8 percent - is this normal? I'm afraid that I have a marriage with the battery, or cause in the firmware. This was observed at firmware with google play and now this. If you simply use the tablet, to climb on the menu and so on. Eats 1 percent to 1.5 to 2 minutes, this is normal or not?
smalink
2013/02/10 - 21:30
no improvement?
Well, that's sad. If only that charge bug could be erase...
mldp
2013/02/11 - 08:30
Looking forward to an update so it can boot up without the powercord. Thanks in advance from Denmark
66 Guest(s)
Devices in use: Desktop (64), Phone (2)
trroll171717
alsoft75
Deaker
Gorael
WhiteD2125
Bokser
