How to open 7fg3 case?
crashogre
Forum Posts: 12
2013/09/27 - 19:34
Does anyone know how to open the 7fg3 case?  The only tutorial I found is for a 10 g2 and has 4 screws.  The 7fg3 doesn't have those.  I need to open it to fix the problem with the charging pin.  I believe it just needs to be re-soldered in place.  I tried prying it open with a screwdriver but no luck.
John
crashogre
Forum Posts: 12
2013/12/03 - 21:22
So I guess no one has any hints on this.  I tried Google to no avail.  I hate to destroy the case to just fix a pin.  Ah well.
Currently Online: djwood1014
73 Guest(s)
Devices in use: Desktop (56), Phone (18)
djwood1014
4ipolino
thomashansmuller11
abro
Yoyoo
sfaris
