[ ROM ] Arnova 7f G3 custom firmware with Google Play and root
wilmer000
2012/08/05 - 09:46
Hi all, I got my new 7f g3, everything seemed fine and the sample music preinstalled played fine. I installed the custom?rom, now no media volume! Silence is not golden, can you help, please?
Dolby
Forum Posts: 64
2012/08/05 - 16:31
Check you settings, sound.
2x Archos Arnova 7D G3 tablets for my 2 sons.
But i have problems to get microsd working on de arnova 7D G3. Help please!
daveyturn
2012/08/06 - 17:17
Brilliant bit of work guys. Both this and the version for my sons 7 G3 worked a treat.
Donation made!
Thanks again,
Dave
2012/08/06 - 17:17
Thanks Dave !
wilmer000
2012/08/06 - 20:23
,Sound setting were ok thanks dolby, oddly enough a restart appears to have sorted it. Loving the new tablet, thanks to you guys. Proper useful functionality!
BigM
2012/08/16 - 21:46
Hi
I just bought a 7F G3 8gb yesterday and flashed it with your custom firmware straight away.....I wanted access to Google Play.
All works fantastically....many thanks, but, when looking at my internal memory it states 504mb total instead of the 1gb that the unit is ment to have? Is this an issue with the new firmware? Also, is there anyway to go back to the original firmware if I so wish?
Many thanks
Mark
Dolby
Forum Posts: 64
2012/08/18 - 18:36
BigM said
Hi
Many thanks
Mark
The internal apps storage is only 512mb. The internal memmory shout be 1GB. With an firemware update you can't change the internal memmory.
sunshine1822
2012/08/18 - 23:47
After I Download everything, when it finish it says that there's an error and that I migth be in an usb port. I have tried several times alredy.
sunshine1822
2012/08/19 - 02:56
Ok, After 3 day Trying in different ways and a lot of errors I decided to uninstall Arctools and Installed again and SUCCESSFULLY Worked! Thank u guys! <3
Dolby
Forum Posts: 64
2012/08/21 - 22:11
Nice to hear that it works now.
hervectop
2012/08/22 - 16:18
URGENT PROBLEM
I've just installed the custom firmware and the playstore works very well.
But since I have installed this custom firmware, the flashplayer doesn't work anymore.
For me it is a big problem because I go on different websites where flasplayer is needed.
Before I could watch to them with no problem, now there is the logo of adobe flash player with the message "you need to install flash player ..."
Notice that in the tablet, I can see that flash player 11 is installed.
Please let me know if there is a solution to my problem...
Thank you in advance,
best regards
stef77370
2012/08/22 - 21:22
Hello ,
This firmware can be put in french? And is that the flash player work?
(Sorry for spelling if there are mistakes, but I am French and I use translator ;) )
2012/08/22 - 21:31
Our custom firmware is based on the stock Android firmware, so it contains many languages including French.
Flash should be no problem, not sure which version is the best, either the on in the firmware, the one from Appslib or more probably the one in Google Play.
Cheers
stef77370
2012/08/22 - 21:38
Ok, thank you very much
hervectop
2012/08/23 - 15:57
Hi Again,
I've uninstalled the flashplayer and installed the flashplayer from Google play and now flashplayer works well with Dolphin Browser and firefox.
Flashplayer doesn't work anymore on the built in web browser but it doesn't matter.
I have another question and it is about skype since I don't know if the problem come from the tablet, the custom firmware, or MY tablet.
I've installed skype from appslib and even from google play, but in both cases, I cannot hear the voice of my interlocutor (video works for everyone, the other person can hear me).
The only way to hear sound was to use earphone.
Please let me know, if someone has the same problem and if there is a solution.
Thank you
king regards
68 Guest(s)
Devices in use: Desktop (61), Phone (7)
