[ ROM ] (test release) Custom firmware with Google Play & partial root for Arnova 7e G2 DT ereader
2012/05/13 - 19:34
I have prepared a test version of a custom firmware for the Arnova 7e G2 DT, your feedback is welcome Wink
Download: http://www.arctablet.com/assets/firmware/Arnova7G2/kasty-ez_arn7eg2dtereader-23-111.zip
The features are identical to our other Kasty EZ firmwares (ex for the Arnova 7b G2): partial root, Google Play/Android Market.
I'll eventually add ext3 support and writable /system thru our kitchen later.
multic, viktor4501, nox426, cknight, pavelv, GrifonLeo
olas
Forum Posts: 32
2012/05/15 - 10:05
is it possible add usb host support?
2012/05/15 - 10:10
I'll see if something can be done when I have some time, I am currently busy with other G2 tablets firmwares.
olas
Forum Posts: 32
2012/05/18 - 10:54
 partial root
does it mean only '/system' is 'ro'
Thanks Received: 268
2012/05/18 - 11:11
yes
ms_green
2012/05/19 - 20:41
Yeah, finally a custom rom for our little e-reader 😀
Thank you so much!
Which version is this based on? (the original one is android 2.3.1)
Does this fix some stability issues of the original firmware and most importantly the "email drains battery like crazy" bug?
olas
Forum Posts: 32
2012/05/20 - 13:50
Have you flashed it, success ?
2012/05/20 - 13:56
Thank you so much!
It's the stock firmware from Arnova  from 2012/12/22 with Google Play integrated. I haven't made any other modifications so far.
2012/05/20 - 13:58
So far I have 2 other users that reported success.
You can give it a try and can always go back to stock firmware if things does not go as you expect.
Stock firmware is here: http://www.arctablet.com/blog/featured/arnova-firmwares-updates/
Flasher if the device is "bricked": http://www.arctablet.com/blog/featured/flashing-arnova-g2-rockchip-2918-rockchip-flashing-tool/
ms_green
2012/05/20 - 21:41
Thank you for replying. Also it´s good to know that you can switch back and forth between firmwares.
However, I won´t install this yet - I got android market and the other gapps running on stock rom and the only reason for me to want root is to be able to remove the faulty email app. (which apparantly does not work yet.)
But I´ll keep an eye on this thread because I´m really glad that someone has created a custom firmware for the 7e g2 🙂
olas
Forum Posts: 32
2012/05/21 - 18:33
You are right, I hope will be upgrade on ICS, if you have readen specs rockchip 29xx
ms_green
2012/05/23 - 17:38
Ok, so how exactly does installing this work?
I figured I just need to unzip the file and put update.img on my sd card.
When I reboot my device, it detects that there´s firmware on the sd card and asks if I want to install it. I click yes, then the device tells me to keep the charger plugged in and it reboots.
However, it doesn´t install anything - when it´s rebooted it´s still running stock firmware with all my settings as they were before.
So what am I missing?
Thanks in advance!
olas
Forum Posts: 32
2012/05/23 - 17:59
could you try rockchip_batch_tool
2012/05/23 - 18:06
Thanks in advance!
After the reboot, you should have the new firmware installed. It looks almost like the stock firmware, with Google Play and other apps added in the application list.
olas
Forum Posts: 32
2012/05/23 - 18:17
usb debug - on
right button-hold
plug in usb cable
install driver
Currently Online: Azabatxe1
135 Guest(s)
Devices in use: Desktop (128), Phone (8)
jacksonrid
usdown
ibob64
