2012/11/12
played a little bit with that "tablet" and it didnt take a long time and the system alert was always coming up. running on lowmemory. so i tried to get over that one with app2sd (via software, f.e. app2sd or those stuff where these function is integrated) but cant really see any getting better behaviour after copying those apps onto sd card.
i read an article somewhere on android help etc, and there was some kind of instruction that to fullly get into real apps started from sd i would need to format the sd card onto 2 partions, one in normal mode, the other with the linux filesystem, and then do some other stuff on it with adroid sdk.
hope the gurus here know what i try to say and express, so they can say yes - no - maybe on that point.
would just be nice to get those most appz from the tablet directly onto sd card and from there started and "hosted" at all.
thx for any help around & best regards - if that here isnt the right place, gimme a hand and show me where best to get into that stuff out there (as mentioned i am really green eared onto appz, the tablet etc at all)Â
2012/11/12
Hello Olas,
now i try my best to explain clearly.
i tried a couple of programs. started with app2sd and then other system control tools which such similiar feature was integrated. none of them really worked at all. sure, i was able to move the app to sd, if the app was moveable at all, but after power off-on phase it was more gone, then fine moved. doesnt matter what the systemcontrol was telling me.Â
then i was reading the article with android sdk and such new stuff, formatting sd card onto 2 different filetypes and tricky the system over that fact - hope i remember right at this moment.Â
are you sure that i need fully root or may (i hope so) partial root would either fit my goal at all?
best regards
Ray
ps. hope that english is more understandable
pss. and if all needs nothing, you may have any hint on running system mem as low as it is possible? (without having that tablet really only for ereading:p)
82 Guest(s)
Devices in use: Desktop (77), Phone (3), Tablet (2)
hakhiem
jenom
kfwacky
fer30
culo1
dfrt
