How much internal memory does my Arnova 7e G2 Dual Touch really have?
nightjockey
2012/04/21 - 10:12
my new 7e G2 is showing an icon for low on internal memory. It says i have less than 150mb available space. NAND flash shows 2.83GB Total  with 2.82 Available. No SD card has been inserted.
I have only installed Appslib, Angry Birds and Guardian newspaper.
The Tech Spec says I should have 4gb internal storage. Where has it all gone then.Cry
What is NAND flash? Is the equivalent of RAM and unavailable as storage?
Help!!
Stuart
Thanks Received: 268
2012/04/21 - 11:02
the nand flash is the main drive of the arnova(here you have the operating system and the apps), not the 4gb space
for example on arnova 7c g2 the space for the system is 120 mB, and another 256 for the applications
on your tablet you should have around 160-200 mb for the system, and another 300 for applications (usually the rockchip based tablets have 512 internal memory)
The 4gb is not the same thing as the nand memory
To overcome this thing the app to sd function was invented, in this way you save alot of space
To check exactly how much space you still have available for apps go to settings/applications/manage applications, and there you will see what is your internal space size available.
Your device should have
512 Nand (internal memory)
512 Ram
4Gb External
nightjockey
2012/04/21 - 17:43
Thanks. I think I understand. Only confusing part is the 4gb internal memory that is in the technical spec which does not appear in the available space. http://arnovatech.com/products/g2/arn_7e/specs.html?country=de&lang=de
Properties
Internal memory • 4GB internal memory + SD card slot (for cards up to 32GB *) Confused
Operating system •  ANDROID ™ 2.3 (Gingerbread)
Screen • 7 "high-resolution, dual resistive touch TFT color display 800 x 480 pixels
Text formats, one • EPUB, PDF (including Adobe DRM ePub and PDF format), FB2, TXT
2012/04/21 - 21:11
the 4gb are more like a sd card only that is inside the arnova 🙂
61 Guest(s)
Devices in use: Desktop (51), Phone (10)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
