Help!!! (touch screen not working)
Related Tags
Erin
2012/07/18 - 09:19
Downloaded Arctools, started downloading custom firmware - didn't get to the end, had to force close of app.  Firmware option wouldn't open again so restarted device.  Is now saying "firmware update found" and is giving me the option to install or cancel but I can't get the screen to respond to any touch, not install, cancel, power off - nada.  I've tried plugging it into my computer to try remove the firmware file and replace it with the last firmware update from Archos but the device isn't being recognised as attached.  What should I do?
Thanks Received: 3171
2012/07/18 - 09:26
You can use Rockchip flasher to flash again the firmware:
either our custom firmware http://www.arctablet.com/assets/firmware/Arnova7G2/kasty-ez_arn7eg2dtereader-23-111.zip
or the stock firmware from Arnova: http://www.arctablet.com/blog/featured/arnova-firmwares-updates/
Erin
2012/07/18 - 09:36
Can you believe, didn't even have to flash it.  switched it on by mistake when about to reset and it just worked.  Clearly admin can work magic.
The custom firmware you've linked above, is that the one I've been trying to download via Arctools?  IE the firmware with google play?
2012/07/18 - 09:40
There are Arnova G2 devices with resistive screen which definitely have some troubles with calibration, glad you got it solve automagically Wink
The custom firmware linked above is the same you have in ArcTools.
multic
2012/11/04 - 14:51
I solve same problem with ADB.
Connect via ADB to your pad and start shell. Delete file udate.img from storage. And execute command "wipe data".
Arnova 7e G2 Dualtouch, HTC Wildfire(CM 9.0)
Currently Online: swan12
88 Guest(s)
Devices in use: Desktop (76), Phone (12), Tablet (1)
swan12
heftpflaster
