The only possible fix I know is to reinstall a firmware with Rockchip flasher.
There has been a similar topic here:Â http://www.arctablet.com/blog/forum/arnova-7b-g3/password-forgotten-on-7b-g3/
On the Arnova 7d G3, you'd need to download the firmware from here and use Rockchip Flasher to send it to the tablet.
You could also use ChildPad (capacitive model) firmwares that should be compatible for the Arnova 7d G3.
2012/09/29
Thanks for the replay, but something is wrong Âż?... I turn off the tablet. Once turned off, i press the reset button with a clip and, while pressing this way the reset button, i connect via usb the tablet to the PC (Windows 7)...Then i launch the Rockchip Batch Tool V1.5, but no device appears so i cannot reset the firmware. I have tryied with 2 different PC but the result is always the same...
On the other hand, is there any specific firmware for the Arnova 7G3?? (The tablet i have to reset...) Thanks!!
I assumed you have a 7d G3 like the first poster, if you actually have an Arnova 7 G3 the procedure is different, check in the Arnova 7 G3 forum, specifically this post:
http://www.arctablet.com/blog/forum/arnova-7-g3/original-firmware-dump-anyone/
86 Guest(s)
Devices in use: Desktop (74), Phone (12)
dubsiki
dubsi
vblxcimdwqgcztgrve
billcamp1984
simoxor33
kontra007
