The custom firmware published in post #37 with Google Play Store and root is now supported in Arctools.
It should work as the Easy install procedure for the Arnova 7f G3, I am interested in getting feedback if it runs all fine on the Arnova 7d G3.
Thank you.
I installed the "kasty-arn7dg3-40-42b" a while ago. And being an absolute beginner on android, at looked fine to me. Now that I'm using it and installed lots of software I recognized something really bad.
As you know the 7dG3 has 1 GB ram and 4 GB internal SD but thats not what is shown to me. actually it tells me I have 2GB overall and no primary SD ?
Thank you, I didn't know that. Yet I'm still confused (not based on this installation, more in Android itself, I suppose):
When I look at the apps, there is only 504 MB available to install Apps, and it shows me 593 MB RAM overall.
Shouldn't it be more when the remaining 2GB are treated as primary space?
2012/07/31
I hope also ther will be an custom firmware to have more apps roam to install on the 7D G3. By Arnova you can only install 512mb for apps. I shout be nice to have 1,5GB roam to install apps on the tablet.
Regards,
Jos
2x Archos Arnova 7D G3 tablets for my 2 sons.
But i have problems to get microsd working on de arnova 7D G3. Help please!
Have you tried the ChildPad capacitive custom firmware with extended data space ?
2012/09/17
Hi Guys, just bought the arnova 7dg3 recently, ive installed the custom firmware via arctools for 7d g3, unpacked it, flashed it, and after the reboot, it looks like a clean install except the wifi is not connecting, prior to the installation of the custom firmware, the wifi works flawlessly, any help would be greatly appreciated, and btw ive reset the device, but still same prob. it keep on saying connecting...but it doesnt connect at all
Try to factory reset your device, go to Settings / Backup & reset / Factory data reset
140 Guest(s)
Devices in use: Desktop (132), Phone (8)
