Custom firmware with Google Play Store and Root for Arnova 7d G3
Dolby
Forum Posts: 64
31
2012/08/06 - 15:22
Admin & Excelletor,
Are testing the custom firmware rom. Coolplease have a little patience.
2x Archos Arnova 7D G3 tablets for my 2 sons.
But i have problems to get microsd working on de arnova 7D G3. Help please!
timika
32
2012/08/06 - 19:26
Dolby said
Admin & Excelletor,
Ok, thank you.
Patience i have.
magneet
33
2012/08/18 - 15:54
how's the test going?
34
2012/08/18 - 16:00
Still a few things to fix then we can publish it, hopefully in the next two weeks.
cr0n0s1
35
2012/08/30 - 08:35
Howdy guys,
you need more images?
Kaaarl
36
2012/09/01 - 04:55
HI! I was just is there any way I can play Dead Space or any other games that doesn't require rooting with this tablet..because when I try to play some guys with it it just gives me white images, I was following your post to check if you were able to root he tablet already. Hoping you can provide us the step by step way of making the tablet work for root
37
2012/09/02 - 21:30
Here is a custom firmware with Google Play (formerly Android Market) and full root for the Arnova 7d G3.
This is a test firmware that should work fine but there are still few things to modify before publishing the final firmware in the coming days.
Download: http://www.arctablet.com/assets/firmware/Arnova7G3/kasty-arn7dg3-40-42b.zip
Flash with Rockchip Flash tool, you can refer to the Arnova 7b G3 custom firmware for more information (see alternative flashing method only, the easy flashing method isn't available for the 7d G3 yet).
tjerkietje
38
2012/09/02 - 22:04
Hi Admin,
This is a SUPERB job!!! It works great for me. Thanks a lot Laugh
timika
39
2012/09/04 - 16:25
How long does it take to do it the easy way.
I dont know if i am be able to do it the other way there is explaned in the video.
40
2012/09/04 - 16:28
The Arnova 7d is not yet support in the easy flashing procedure, I should add it soon.
As you can see in the video (here on an Arnova 7f G3) it will just take about 10 minutes to complete.
timika
41
2012/09/04 - 17:36
Is it difficult to do?
What are the chances for going wrong and what then?
I dont want to brick my tablet.
Do i only need the image you posted?
I saw the video, and i see that it will update with a program on your PC.
Kayakfl
42
2012/09/05 - 05:24
Greetings all, new member here. I just purchased the Arnova 7d 3g and have tried for hours to get my computer to recognize and install the drivers correctly in Windows 7-64 and XP. I have downloaded the required files and followed the procedure but no go. Can someone help?
I think I am putting it into the correct mode: I hold down the reset and then the power button and let go and I get a screen with the android character on his back with a "panel" open and a red triangle. All this with the cable unplugged. I then start RKbatch Tool and that window opens up fine.
Then I plug in the cable and my computer recognizes something and identifies it as AN7d3g and when I direct it to the proper folder for the drivers, it doesn't find the right one or provide a list for me to choose from.
What am I doing wrong?
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
43
2012/09/05 - 08:24
Firstly, connect the tablet with the usb cable to your computer. Then quickly press first on the reset and then on power button. The screen should go black and unknown device should appear. If the tablet just keeps restarting, try holding down the reset until unknown device appears (it is the easiest to monitor in the device manager).
Kayakfl
44
2012/09/05 - 13:06
I got it, thanks for your help. Seems to be running good. Any idea when final will be ready?
Thanks.
Kayakfl
45
2012/09/06 - 17:47
Greetings again!!!
I must say that the custom firmware that you created is awesome!!!! It really makes this a very nice tablet. I don't know what other people paid for theirs, but I paid $69.00 with no sales tax at Brandsmart in Miami during their Labor Day sale. Your firmware makes it worth keeping!!!!
139 Guest(s)
Devices in use: Desktop (138), Phone (1)
