I use a sandisk sd card, class 10, 16 GB no problems with the card
Did you tried to re-format the card ?
2013/07/17
globula_neagra said
fat32
Hi again, just formated 2 micro sd cards to fat32 and no luck.
Am I doing something wrong?
It should appear where? I search using files manager and found a folder called sdcard and something called external sd. In config on the option storage it keaps showing, please insert sd card. Should i return the tablet asap?
The external Sd card is the one that you insert.
Insert an sd card, and enable usb storage, see it something appears on the pc.
The sd Card appears in Storage as SD CARD
2013/07/17
hi again, how can I enable usb storage? Isnt always on? It seems that the sd card isn`t being recognized by the tablet, maybe a faulty connection (hardware).
Yes, it might be, tough you are the first one that is reporting this issue.
To enable usb storage from the tablet = enabling access to the internal and external sd card, this is done from the tablet.
Currently Online: firmwarefile
72 Guest(s)
Devices in use: Desktop (56), Phone (17)
firmwarefile
mongol
country822
vovandolgan
kenjakenjavitis
Vugare
