Arnova 7C G3 DEV/FIRMWARE TOPIC
Thanks Received: 268
61
2013/08/20 - 18:55
First page, 3`rd post i think ?
toxic2013
62
2013/08/21 - 00:08
Hello guys,
Could explain all the steps to put the new firmware on Arnova 7cg3 Confused ... sorry, I do little, if anything, I understand this. A little video helped lol
Ja could put my tablet in root, already used the titanum backup and ... how to use the flash?
Sorry for the ignorance friends
(translated by google)Embarassed
toxic2013
63
2013/08/21 - 00:09
Hello guys,
helped lol
...how to use the flash?
64
2013/08/21 - 00:31
toxic2013 said
Hello guys,
helped lol
Did you backed up your device ?
toxic2013
65
2013/08/21 - 02:42
yes i did with titanium backup
66
2013/08/21 - 10:45
I am refering to post number 4 from the beginning of the topic.
Also did you read this from the first post ?
WHAT YOU SHOULD DO BEFORE YOU FLASH THIS FIRMWARE !!!
-back-up your tablet using the method from bellow because there is a chance in getting an unresponsive touch-screen !!!
-when I say back-up I am referring that you should dump the system and the boot partition !!!
-I am not responsible for any bricks
REMEMBER, FIRST BACK~UP AND THEN FLASH
prest0n
67
2013/11/20 - 14:58
Hello globula_neagra. Flashed this tablet to the rom, the touch-screen stopped working, backup  have, but how to download the tablet mode recovery? Sorry my english
68
2013/11/22 - 17:10
As I said in the first post, if you don`t back-up your device you might end up with an unresponsive screen.
The recovery mode will not help you with this issue.
prest0n
69
2013/11/28 - 15:45
Understand one! I have a backup firmware obtained from cwm recovery as you asked before you flash your rom! Now I want to restore your backup from cwm recovery, but can not get there! How do I get cwm recovery???
ivanxx
70
2014/10/06 - 00:51
Hi there!
Just registered on the forum to let you know a possible solution for unresponsive screens:
What I've done after flashing the .zip ROM from the first post (and getting an unresponisve screen) is reflash my original boot.img (yes, the one you should've backed up in the first place). After that the new ROM works OK (except for a wiper app force closing a couple of times on each reboot).
On a side note, I'll also tell that it looks like it's impossible to install the recovery.img. Every time I flash it and reboot I get double-booted into the normal boot process... So, what you've got to do is reboot in bootloader (adb reboot bootloader or power on+volume key) and check with fastboot services if the device is present (the screen is black on bootloader mode for this tablet, don't let it confuse you). Once in bootloader, fastboot boot recovery.img will force the tablet to boot in CWM recovery so you can play along :-)
I know it's been a while since the last posts about this tablet, but maybe someone will come across this in the future and will probably benefit from these comments.
Cheers!
domilan90
71
2015/09/24 - 19:45
excuse me... i have a problem with an Arnova 7c g3.
my tablet as blocked on lock page (with a password that i have forgot) and i have tride to unlock but i haven't success.
i can't entry in recovery mode and  i can't flash a firmwre (i don't have debug devices activated).
how can i do to unlock it??
thank's to all.
excuse me for the mistakes, but i'm italian 🙂
JEssicannn
Forum Posts: 252
72
2019/10/23 - 01:37
Currently Online: 5256makc
134 Guest(s)
Devices in use: Desktop (130), Phone (5)
5256makc
e-victor
vienzo
superdavex
giorgioo@freemail.hu
suchitratiwari
