Arnova 7C G3 DEV/FIRMWARE TOPIC
hacko
Forum Posts: 11
46
2013/06/21 - 11:31
globula_neagra said Tun.ko modules available http://www.mediafire.com/?920micpj5d887h8
Thanks i will try this week with my VPN.
Success!!! all work!! Thank you very much!!!
herzenston
47
2013/07/06 - 20:37
Hi!
I managed to root the an7cg3 and sent it into fastboot via adb reboot bootloader
i installed the adb usb drivers, but as soon as the tablet enters fastboot, windows doesn't recognize it anymore and i can't find a way to flash cwm recovery onto it.
the device manager in windows shows an android device that is missing a driver and none of the drivers i tried are working. i tried the drivers from this topic and the ones from superoneclick but windows keep telling me that those are not the right drivers.
i don't know what to do. as i said, my tablet is recognized by windows in usb debugging (driver installed without a problem) and i thought that was all the drivers it needs.
(sry for my bad grammar, german user ^^)
Thanks Received: 268
48
2013/07/06 - 21:09
What windows you have ?
You can flash the cwm, also via terminal, just copy the cwm to the sdcard, and swap some values
dd if=/sdcard/recovery.img of=/dev/block/mmcblk0p16
sync
reboot recovery
sdcard is the arnova storage
herzenston
herzenston
49
2013/07/06 - 21:21
thy for the quick reply!
I'm using windows 7.
what terminal do you mean? (I'm really new to this, sorry!)
(Okay i think i found the terminal. I installed terminal emulator from the applib. i entered the command you wrote above, but it tells me /dev/block/mmcblk0p16: cannot open for write: Permission denied)
50
2013/07/06 - 23:32
type
su
before entering any commands
herzenston
herzenston
51
2013/07/06 - 23:53
Recovery works fine now! Thank you so much!
Just need to grab an external sd card tomorrow and flash the custom firmware!
52
2013/07/07 - 00:04
Please do a back-up before, otherwise you might end up with a tablet on which the touch screen will not work.
herzenston
herzenston
53
2013/07/07 - 14:09
There I am again..
So i made a complete backup, dropped the custom firmware on my micro sd, went to recovery mode and selected apply update from external storage, when this showed up:
-- Install /sdcard ...
Finding update package...
Opening update package...
Verifying update package...
E:signature verification failed
Installation aborted
I tried to google this error message, and found something about the command "toggle verification" but cwm is missing this command.
sry for still failing with this!
54
2013/07/07 - 14:26
Disable signature verification from CWM
toxic2013
55
2013/07/11 - 22:18
-- Install /sdcard …
Finding update package…
Opening update package…
Verifying update package…
Installation aborted Cry
( X2 )
thanks
toxic2013
56
2013/07/15 - 05:29
Hi, someone already got a custom firmware running on 7cg3? Confused
hugs
57
2013/07/15 - 09:51
The most of the people which posted have.
toxic2013
58
2013/07/15 - 14:25
Already tried this firmware but as informed, check failed ... someone can help me?
59
2013/07/16 - 10:30
Did you flashed the recovery ?
Double check the version, to be sure that you don`t have the stock one.
tudo
60
2013/08/20 - 17:49
Where i can find instructions for backup?
Tks
Currently Online: Stellar7, WhiteD2125
102 Guest(s)
Devices in use: Desktop (69), Phone (35)
WhiteD2125
Bokser
hamishduke
squal
squalangel
anqilan456
