Arnova 7C G3 DEV/FIRMWARE TOPIC
micronexus
31
2013/05/27 - 10:43
I used your script, I saw "Press any key to exit and have fun with your rooted phone", I have no error message during the script. I used the script even under windows (using the right adb driver) to try to understand where I am wrong.
But when I use:
adb shell mv /system/recovery-from-boot.p /system/recovery-from-boot.p.old
I have "No such file or directory" message.
I see the SuperSU correctly installed in my tablet.
Have I any hope to solve the problem?
Thanks in advance....
Thanks Received: 268
32
2013/05/27 - 13:48
try to find that file in system/etc/recovery-from-boot.p and remove it
or in the first location /system/recovery-from-boot.p
micronexus
33
2013/05/27 - 15:56
I tried also
mount -t ext4 -o rw,remount /dev/block/mmcblk0p12 /system
to make it writable.
I can write and remove files in this directory, the problem is that I cannot find the file recovery-from-boot.p.
34
2013/05/27 - 18:32
My advice is dump your boot.img and system.img first.
I am uploading a fastboot version flashable firmware of the zip file in the first post.
It would be available here
http://globula.arctablet.com/New%20FW%20for%207CG3/
The file should have around 246 Mb, at this moment is uploading, it should be up in about 30 minutes.
As i said, first dump your current files from the tablet, so you will have a back`up available, copy them somewhere safe, and then try what i will upload.
micronexus
35
2013/05/27 - 19:02
I did:
dd if=/dev/block/mmcblk0p16 of=/external_sd/recovery.img bs=4096
dd if=/dev/block/mmcblk0p12 of=/external_sd/system.img bs=4096
dd if=/dev/block/mmcblk0p8 of=/external_sd/boot.img bs=4096
so I have the three img files saved.
To be clear, when your img file will be available I have to do:
fastboot flash system yourimage.img
Is it correct?
Thanks!!
36
2013/05/27 - 19:05
Yes, do the same with the boot.img that is available in the zip, also with the recovery
fastboot flash system system_new.img
fastboot -w
And you should be fine.
The file should be now uploaded
The exact size of the file is
245.8 MB (245,760,000 bytes)
micronexus
37
2013/05/28 - 16:13
I am again here...
I flashed the three partitions, I had no errors.
But the devices doesn't boot, it always shows an android intro with flames :)
I waited for two hours...
Now I will flash it again...
Any suggestion?
38
2013/05/28 - 21:01
try this system_new.img from here
http://globula.arctablet.com/Test/
micronexus
39
2013/05/29 - 10:01
I used your last system image file, I had no errors, the process was faster than using the previous system image file, but... now the device boots, it is charging, but touchscreen  doesn't work...
40
2013/05/29 - 12:24
well, i was somehow expecting this, that`s why i told you to back`up the system.img
try to inter in recovery, you can do that if the usb debugging is enabled, or using an otg cable with a mouse, by going to system,about tablet,system updates. and flash the zip from the first page
micronexus
41
2013/05/29 - 18:16
dear globula,
yesterday I thought I bricked my tablet. I am lucky and it is not true, but... I don't understand why with yout boot, recovery and system images I cannot solve the problem!
Can you explain me where am I wrong?
thanks in advance!
42
2013/05/30 - 13:15
Well, from my knowledge there are 2 versions of 7C G3 and of course it also relates with the fact that i am able to re-compile my stuff and re-test when i get something wrong, I cannot offer you a straight answer, my advice to you now, would be to upload the system and boot and share them with me, so i can check if something is different.
The tablet is virtually unbrickable if you don`t delete some partitions from it, and my flashing method does not affect in any way the integrity of tablet in terms of deleting partitions.
43
2013/06/15 - 17:54
hacko
hacko
Forum Posts: 11
44
2013/06/18 - 09:52
globula_neagra said
Tun.ko modules available
http://www.mediafire.com/?920micpj5d887h8
Thanks i will try this week with my VPN.
45
2013/06/18 - 12:59
I am trying to build an overclockable kernel now 1.8 Ghz max so keep an eye :) .
Currently Online: Stellar7, WhiteD2125
104 Guest(s)
Devices in use: Desktop (69), Phone (37)
WhiteD2125
Bokser
hamishduke
squal
squalangel
anqilan456
