Arnova 7C G3 DEV/FIRMWARE TOPIC
hacko
Forum Posts: 11
2013/04/23 - 12:44
globula_neagra said
You are the second that reports this, i need to have a look on what is happening.
In the end if i don`t find a solution i will provide a low level reflashing tool.
See PM ^.^
Im afraid with flash the system, i did the backup of the system and boot, i forgot the recovery.
Thanks Received: 268
2013/04/23 - 13:06
i think that is something related with the fact that the stock firmware re-writes the recovery partition at each start-up
hacko
Forum Posts: 11
2013/04/24 - 10:11
More information if you need.
AN7CG7
4.0.3
FW8930m-V0.3.7.0
3.0.8-perf
chenqh@ubuntu-int #1
IML74k SW:V0.5.3.0-user.release.20120620.092316
hacko
Forum Posts: 11
2013/04/24 - 12:32
So can you provide me a low level reflashing tool if you believe in? i really need that CF
also will make a donation if I get a valid tun.ko for Openvpn
2013/04/24 - 13:43
make a dump of your system.img
A bad news is that the low level format tool is not working anymore due to a licence issue with the company of which was registered the tool.
Later edit: It seems that is a general problem with that tool, also on other tablets made by the same manufacturer the tool is not working anymore.
I tried a lot of tun.ko`s sadly i did not found one working, we need the kernel source to compile one.
hacko
Forum Posts: 11
2013/04/25 - 10:48
So, any solutions?
can i flash system and replace with custom firmware with the fastboot utility?
2013/04/26 - 01:24
So, any solutions?
I will prepare in the weekend a flashable via fastboot firmware.
hacko
hacko
Forum Posts: 11
2013/04/26 - 10:05
So, any solutions?
so in your CF there are a valid tun.ko for Ovpn?
2013/04/26 - 10:19
No, because i don't have the kernel source to build one.
hacko
Forum Posts: 11
2013/04/26 - 10:56
Dont have the kernel source of you our CF?....shit...i believe it.... >.<
2013/04/26 - 18:40
i did not build the firmware from scratch, i just dumped the firmware, added root, busybox, init.d and that`s it.
i did tried before to compile a tun.ko for a russian guy using huawei u8860 source code but without any results.
If you don't believe me, is your choice, if i would have had the kernel source, this tablet would have had by now cm9 at least.
micronexus
2013/05/24 - 16:37
hello,
I am experiencing a problem with my arnova 7c g3.
I cannot boot in recovery mode!
I am using adt-bundle-linux-x86-20130514 on Debian 6.0.
I did:
adb reboot bootloader
fastboot flash recovery recovery5.5.0.4.img (with ok messages)
fastboot continue
and then I tried:
adb reboot recovery and system-update and volume up+power but nothing!!
I obviously copied the zip file in the sd card.
Please help!
micronexus
2013/05/24 - 17:39
it is not working because the stock firmware is always flashing back the stock recovery upon start-up.
Delete the file recovery-from-boot.p from /system
Of course this involves having your tablet already rooted, you can use the tool provided in the first posts.
micronexus
2013/05/24 - 18:39
thanks for you reply
As I said before I am using linux.
any suggestion to root the device under linux?
I am sorry I am not a great expert :)
2013/05/24 - 21:44
you can open the script, and use the commands by typing them ?
Currently Online: Stellar7, WhiteD2125
98 Guest(s)
Devices in use: Desktop (62), Phone (38)
WhiteD2125
Bokser
hamishduke
squal
squalangel
anqilan456
