Whats Best!?????please advise!
lohtse
Forum Posts: 157
2012/06/01 - 19:43
Ok Folks..
Killed my 8G2 and got one of these instead...
So now I need a little advice and yes looked through the forum but it's a dang mess!!! Links not working,Info on roms confusing etc... I just gave in!!!!
This is what I need advice on..
1) best fully working rom.Rooted with market etc
2) tutorial(simple) on flashing.
3) advise on app2sd and ext2 partition(if pos)(similar to advent vega at a guess)
4)Clockwork mod
5)memory management best way to do it.(similar to advent vega at a guess)
simple really.. Just advise and provide links(working ones)
Am not a new comer to flashing tablets or phones I just need pointing in the right direction and then am happy...
regards
Lohtse
Thanks Received: 3177
2012/06/02 - 00:32
lohtse
Forum Posts: 157
2012/06/02 - 10:47
Thank you for your reply..
And will take a look...
Any of the roms support ext2/4 partitions?? or will I need to use link2sd?
Thanks Received: 268
2012/06/02 - 16:04
sethialpha`s rom supports the ext3 and ext4 partition layout
my rom does not support the ext3 and ext4
all the roms have the stock android memo managment.
there is a clockwork mod in sethialpha`s rom topic, can be flashed via fastboot.
tutorials are allready posted on the forum.
Currently Online: ri9000
70 Guest(s)
Devices in use: Desktop (61), Phone (10)
squal
squalangel
anqilan456
havetoregister
werasler
5256makc
