2012/12/01
I bought an ex display 7c g2 from ebay but i have noticed sometimes the screen jumps about from thing to thing, and somtimes progs close for no apparent reason, sometimes with a warning sometimes without, is this normal as its a cheap tab?
Angrybirds is very suseptable, mid play it somtimes zooms in and out by itself, and is unplayable,
I did a factory reset but the arnova is still unpredictable, but is often fines for hours at a time.
Cheers rob
did you tried the custom rom ?
from what i remeber the only issue with this tablet was:
-after you leave it over night in a cold place, the screen will have some strange reactions, like someone else is pressing it, to solve this, i was shuting down the tablet, and turn it on back.
-not all the flash players version in the 10* range version where working.
You can also open the tablet, and see if something loose.
i make the same offer to you
i can flash your tablet via a remote connection for a 5`ver
2012/12/18
I am getting the same problem with my 7CG2: it randomly exits the apps by itself. I thought that was a hardware fault and thought about getting it to the warranty service, but then I thought it may need another ROM, or a factory reset to the original one (and that's how I got on this forum, btw).
So, it's a software problem? If so, what do you recommend, to update with a custom ROM (the one including GooglePlay seems interesting) or stock ROM factory reset (or flash) will do?
Thanks.
Currently Online: leplucooldu14
74 Guest(s)
Devices in use: Desktop (67), Phone (8)
cutierogue
hans41
