2012/05/05
     Hi my Aranova 7c G2has stopped working it is after seeing some videos I felt it hot then I charged it all night and surprised to find it no working and only arnova logo    nothing happened after that pressing the reset let it without charging charged it all night coping a firmware from arnova site on SD all of the previous tries are gone without any hope this the second time for me but the first time it start working after few days by itself will you help me pls
there is no firmware for arnova 7c g2, i can help you tomorrow if you want via team viewer
please prepare in a folder the programs, android sdk, java sdk.
2012/05/05
Hi, just purchased 7C G2 and I love it. I've got it so it won't start - just the android logo appearing. Can anybody help? I've installed SDK tools, and driver. The PC acknowledges the device but Fastboot does not see it - when I check for drivers in Fastboot nothing happens. I really don't want to send it back.
2012/05/05
thanks - tools installed. Device can't be put into usb debugging mode as it is either off or displaying the android logo - so adb devices does not see it. how can i get the device seen by the PC? Windows device manager is seeing it as android composite ADB interface. Drivers installed ok via superoneclick but it is otherwise not seen bythe PC.
2012/05/05
Thanks to Globula_neagra I don't have to post my tablet back to the seller. He is one clever guy. Recovered tablet with remote help. I learned about using power switch and volume up keys together to go into recovery, then connect to PC whereby adb commands can be used. Should be OK to mess it up and recover myself in future.
2012/11/09
globula, please help me too sir
my problem is the same here. my arnova 7c g2 is stuck at the arnova logo and it doesnt boot up.
i am just listening to music with PowerAmp and then hangs out. i pressed the reset button because it cannot turn off by just holding down the power button.
i am very glad if you help me. please?
arnova 7c g2
Read this
and this
And if you still don`t manage to fix the tablet alone read this
http://www.arctablet.com/blog/forum/archos-arnova-general/flashingunbrick-project/
2013/06/29
I have read and follow the steps in this tutorial and solved the problem. Thank you.
Another question, what is the best way to have google play to work on my Arnova 7c g2.
83 Guest(s)
Devices in use: Desktop (74), Phone (9)
smoky551
KarlAnkho
jasondweller
2256667898
EDINTELL
ilval
