two speakers or only one?
sanaldi
Forum Posts: 17
2012/06/21 - 10:49
it seems it has two speakers but only one works. Is it about Rom? What about yours?
Thanks Received: 268
2012/06/21 - 11:50
from what i know there are two
on my tablet both are working.
sanaldi
Forum Posts: 17
2012/06/21 - 21:17
i notice that today. i restocked the device rom but one of them works. is the any app for making test of right-left speakers?
Thanks Received: 3177
2012/06/21 - 21:20
I used Stereo test application to check the channel separation on the Archos G9, it should work on the Arnova 7c G2 too.
sanaldi
Forum Posts: 17
2012/06/21 - 21:24
thanks i will try
sanaldi
Forum Posts: 17
2012/06/21 - 21:55
i tried. it uses the same speaker (left) for left and right channel at the same time. does it mean that my arnova 7c g2 has one speaker? or what is wrong?
JollySonX
2012/07/03 - 13:35
I opened mine up to refit the screen cable an noticed only 1 speaker but a hole for another 1, i did a video but thanks to a stupid setting only recorded 1 frame per sec lol
Im going to do another tonite ( i noticed no videos for it)
Hope this helps
JollySonX.
sammonsmx
Forum Posts: 36
2012/07/06 - 00:32
There is only one physical speaker installed.  wiring is in place for two.  I may try a second speaker next time I open up, and will post.
sanaldi
Forum Posts: 17
2012/07/06 - 00:41
but i have sent it to technical service. i wonder that it is a fault or not?
sammonsmx
Forum Posts: 36
2012/07/06 - 01:14
I have three 7C G2 devices.  All have just the one speaker.
Currently Online: hamishduke
76 Guest(s)
Devices in use: Desktop (69), Phone (8)
hamishduke
squal
squalangel
anqilan456
havetoregister
werasler
