Tablet will not talk to laptop
sharon
2012/04/06 - 00:58
I have the problem of my tab stuck on the Android logo.  It will boot into fastboot using the volume - with power key.  But will not connect to laptop.
I have installed and have a working ADB and fastboot, but they won't talk to each other, I'm wondering if some kind of USB problem as tried different cable and still no joy.  Tablet is only 2 weeks old and worked fine last weekend.
Any suggestions or remedies please.
Should be using Arnova 7c G2
Thanks Received: 268
2012/04/06 - 01:32
do you now the command to see if the tablet is in fastboot ?
sharon
2012/04/06 - 14:49
I typed in fastboot devices and it just returns to c prompt.  No information of tablet displayed.
Should have mentioned tablet should be in fastboot as i did the following prior to going into adb
Reset tablet
Held down volume - and power on key
Waited for tablet to flash then connected to laptop.
2012/04/06 - 15:31
and you have all the drivers instaled ?
sharon
2012/04/06 - 16:54
I think there may be a problem with the USB drivers as the tab is now showing as unknown device in Control Panel, they are loaded into the sdk Extras folder.
After years of auto installs on windows getting my head back into dos etc is not easyEmbarassed can't even remember a lot of the Xenix commands.
Don't really want to have to revert to the 7 2G as the 3G was one of the important factors in going for this model.
Thanks for the help so far.
2012/04/06 - 17:30
well, you need to read this
http://www.arctablet.com/blog/forum/arnova-7c-g2/what-is-adb-and-fastboot-how-to-install-and-use/
because i think you skipped a step
sharon
2012/04/07 - 13:15
Hi again,
Well so far I have got as far as trying to install the arnova drivers in the tutorial set up, it says to put tabley into debug mode which is not posible as I can't access then tablet.  What else can be done (other than slinging this out the window) or am I using the wrong tutorial?
Also when I download the tutorial files from the link provided they are downloaded in docx format.  I don't have word on this machine, are they possibly available as pdf.
2012/04/07 - 13:34
Here, is the same thing.
The tutorial is personalized for the arnova familly devices.
Currently Online: hoholms
45 Guest(s)
Devices in use: Desktop (40), Phone (6)
hoholms
rammaiden
iongeorge411@gmail.com
legrandhommer
mindra
xstouf
