Stuck on Arnova Screen
hilltophousemjh
Forum Posts: 13
2013/07/08 - 22:54
Hi. I've standard as 7c g2, that has not been flashed. Its has loads of apps on it but now at boot up it just sticks on the Arnova boot screen. Is there a way to use fastboot (or something) to reset it but not lose any user data?
Thanks Received: 264
2013/07/08 - 23:02
No, fastboot allows only to:
flash partitions
wipe data
format (in some cases)
If you have usb debugging enabled, you can find out what is causing the boot loop and try to fix from there.
You can flash a custom boot.img which has the usb debugging on by default.
JEssicannn
Forum Posts: 252
2019/10/23 - 01:43
67 Guest(s)
Devices in use: Desktop (65), Phone (2)
djwood1014
4ipolino
thomashansmuller11
abro
Yoyoo
sfaris
