SOS Arnova 7c G2 3g
Alex9000
2011/12/19 - 18:58
Hello
My problem has Arnova
when i start i said:
Stopping an unexpected application wizard (process com.android.setupwizard). Please try again.
and i can not start it
there is no way to do a hard reset?
a combination of buttons to reset to factory settings?
thanks
Thanks Received: 3170
2011/12/19 - 19:13
The Arnova 7C G2 manual does not seem to cover that issue
http://arnovatech.com/support/manuals/UserGuide_Arnova_7cG2_PN109940_book.pdf
You can try to install adb (check Google for that) then issue:
adb reboot recovery
from the command line.
Let us know how it goes.
76 Guest(s)
Devices in use: Desktop (70), Phone (6)
hakhiem
jenom
kfwacky
fer30
culo1
dfrt
