SD card crashed
sillygranddad
2012/05/17 - 15:30
getting message sd card damaged lost all data including apps. Phone memory ok. My son says card gone, anyone had this problem before I go and buy new card.Cool
Thanks Received: 268
2012/05/17 - 16:13
1)put the sd card in another device, connect it to computer and perform a scan, put it back on the tablet and it should be fine
2)remove the sd card from the device and put it back in
sillygranddad
2012/05/18 - 10:25
Thanks for the tips. Already tried 2 but no go.Don't have any other devices with micro sd but will find some who has or  get a converter and give 1 a try.Thanks again let you know.Smile
sillygranddad
2012/05/19 - 18:52
Thanks globula-neagra tip 2 worked fine going to try root next so may be back.Laugh
sillygranddad
2012/05/19 - 19:03
It was tip 1 that worked (me being stupid) the scan and replace sLaughd anyway you get another thanks
Currently Online: hoholms
51 Guest(s)
Devices in use: Desktop (45), Phone (7)
hoholms
rammaiden
iongeorge411@gmail.com
legrandhommer
mindra
xstouf
