Tablet stuck on Android logo / Reste bloqué sur le logo android
sebmickey94
2012/02/09 - 16:03
Bonjour , j ai ue tablet arnova 7c G2 et quand je la demare elle reste bloqué sur android
J'ai essayé le reset,bonton volune et home Rien
Si quelqu'un avait une solution
Merci
Cordialmenet sebastien
Hello, I have ue tablet ARNOVA 7c G2 and smith it when I get stuck on android
I tried the reset, and home Nothing BONTON volune
If someone had a solution
thank you
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/02/09 - 16:20
Merci
thank you
Read the previous post on this section, how to unbrick arnova
sebmickey94
2012/02/09 - 16:46
Merci j'ai deja essayé
Rien ne fonctionne
Thank you I have already tried
Nothing works
Thanks Received: 268
2012/02/14 - 13:04
Try this method if you have windows xp, vista , 7
Instal Android sdk in c:\
Instal http://www.arctablet.com/blog/featured/adb-driver-update-for-archos-arnova-devices/
After that connect your arnova to the pc, and press the Power button and the volume key - !
Wait till it flash like 1 second, the screen will be black, but now the arnova is in fastboot mode.
Now, go in start/run/cmd(xp version) go in start/search aplication/type cmd in the search tab, and press enter.
A commander black windows will open.
Now type in the commander
C:\Android\android-sdk\platform-tools\fastboot devices (this command shows you if the arnova is connected, also this is not a normal path for the android sdk instalation, so if you instal`it in program files you should put the correct path C:\program files\Android\android-sdk\platform-tools\fastboot devices)
After that type in cmd
C:\Android\android-sdk\platform-tools\fastboot -w   this command will factory reset your arnova
If this not works, refer to post 20 from this thread
http://www.arctablet.com/blog/forum/arnova-7c-g2/danielvd_arndroidianimoddedrom/page-2/
Currently Online: hoholms
47 Guest(s)
Devices in use: Desktop (40), Phone (8)
hoholms
rammaiden
iongeorge411@gmail.com
legrandhommer
mindra
xstouf
