Problem with 3G
kuro01
Forum Posts: 12
2012/04/30 - 16:51
I have a problems with enabling 3g data connection. When i've just rebooted device - all work fine, but over time when i disable 3g and trying to re-enable it - doesent work. And i must reboot device every time i want to enable 3G. On my phone(lg p500) it work well(with the same SIM card and settings).
I have this bug on stock firmware and DanielVD rom.
Maybe somebody know how to fix it?
Thanks Received: 268
2012/04/30 - 18:12
try another firmware, i thing is a bug of the rom itself.
kuro01
Forum Posts: 12
2012/04/30 - 19:07
I tried Nano CFW rev13b. 3G works much better but redesigned theme in this rom is awful(stock theme is better). And remains just Glob_Be_One ROM but i've no info about 3g fixes in this rom.
2012/04/30 - 19:12
a 3fix will be available in the fallowing days, you can use a custom theme
try this one, is made by me http://www.mediafire.com/?x2j57qzv3iqosag
You can flash`it via cwm
kuro01
Forum Posts: 12
2012/05/03 - 08:46
Tried Nano CFW one more time - the same problem. Cry
In the mobile network settings - data enabled, in info about device >> Status >> Mobile network state >> Dosconnected.
2012/05/03 - 12:37
did you had this problem also with my rom ?
kuro01
Forum Posts: 12
2012/05/03 - 13:25
i tested 3g on your rom. at home it connected only 1 time? and connection wa lost. it shows the maximum signal level but don't connect.
Outdoors the situation is a bit better. It connect, but connection is very unstable. I've already tried 2 SIM cartes of different providers(all works great on my phone).
kuro01
Forum Posts: 12
2012/05/03 - 16:35
I bought this tablet just besause it had 3g, but it isn't working. and i can't return it cause i flashed CWM, and there is no stock recovery.img. i don'n know what to do....Frown
45 Guest(s)
Devices in use: Desktop (41), Phone (4)
hoholms
rammaiden
iongeorge411@gmail.com
legrandhommer
mindra
xstouf
