Making network location services work correctly on the 7c G2
jameslewisuk
Forum Posts: 79
2012/01/29 - 12:08
I posted about this in the nano firmware thread but think it deserves discussion in it's own topic.
Network location services via 3g or wifi doesn't seem to work correctly, applications that call for location such as news/weather or beautiful widgets can't access location.
I did think this could be the fix… (I think it's part of the fix)
If you look inside
/system/framework/framework-res.apk
If you decompile that you can see
/res/values/strings.xml
There are these lines in that xml file:
<string name="config_networkLocationProvider">@null</string>
<string name="config_geocodeProvider">@null</string>
I believe they should be:
<string name="config_networkLocationProvider">com.google.android.location.NetworkLocationProvider</string>
<string name="config_geocodeProvider">com.google.android.location.GeocodeProvider</string>
I de-compiled framework-res.apk, edited the strings.xml then recomplied and zip aligned it.  The location services still didn't work with the edit.
I believe the network location services provided to apps works via NetworkLocation.apk a google apk in the systemapp directory
I am using my ZTE skate android phone to make comparisons.
If I look in /data/system/packages.list on my ZTE skate I see this line:
com.google.android.location 10018 0 /data/data/com.google.android.location
Which shows that NetworkLocation.apk is installed
If I look in /data/system/packages.list on my 7g G2 tablet, the line is missing, even though NetworkLocation.apk is in the /system/app directory.
It leads me to believe that the 7c G2 tablet does not like the version of NetworkLocation.apk
Further to this, if I try to manually install NetworkLocation.apk from the systemapp directory on the 7c G2, I get the message "application not installed" when I run the APK to install it.
Therefore, I believe that the version of NetworkLocation.apk that Arctools puts on the devices is not compatible with the device, and isn't actually installing but just sits in the /system/app folder.  (A bit like compass and phone which don't do anything either)
I wonder if we can get a NetworkLocation.apk that will work ?
jameslewisuk
Forum Posts: 79
2012/01/29 - 12:38
AndroidManifest.xml from inside NetworkLocation.apk, you can see it references to the strings in values.xml in framework-res.apk
<?xml version="1.0" encoding="UTF-8"?>
-<manifest xmlns:android="http://schemas.android.com/apk/res/android" package="com.google.android.location"
android:versionName="2.2" android:versionCode="8" android:sharedUserId="android.uid.system"> <uses-sdk android:targetSdkVersion="8" android:minSdkVersion="8"/>
<uses-permission android:name="android.permission.RECEIVE_BOOT_COMP LETED"/>
<uses-permission android:name="android.permission.INSTALL_LOCATION_ PROVIDER"/>
<uses-permission android:name="android.permission.ACCESS_WIFI_STATE "/>
<uses-permission android:name="android.permission.CHANGE_WIFI_STATE "/>
<uses-permission android:name="android.permission.READ_PHONE_STATE"/>
<uses-permission android:name="android.permission.ACCESS_COARSE_LOC ATION"/>
<uses-permission android:name="android.permission.INTERNET"/>
<uses-permission android:name="android.permission.WAKE_LOCK"/>
<uses-permission android:name="android.permission.WRITE_SECURE_SETT INGS"/>
<uses-permission android:name="com.google.android.providers.setting s.permission.READ_GSETTINGS"/>
<uses-permission android:name="com.google.android.providers.setting s.permission.WRITE_GSETTINGS"/>
-<application android process="system" android:label="@string/app_label"> -
<service android:name="NetworkLocationService"> -
<intent-filter>
<action android:name="com.google.android.location.NetworkL ocationProvider"/>
<action android:name="com.google.android.location.GeocodeP rovider"/>
</intent-filter>
</service>
<activity android:name="ConfirmAlertActivity" android:excludeFromRecents="true" android:theme="@android:style/Theme.Dialog.Alert"/>
</application>
</manifest>
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/01/29 - 19:07
framework-res' string.xml is just for translation, changing here won't do anything different.
You would need a NL.apk that runs on the 7c g2
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
jameslewisuk
Forum Posts: 79
2012/01/30 - 21:49
Thanks setialpha,
That version shows as installed on settings > "all applications" list but does not seem to work
Wonder if there is one that willl work... any ideas what it's based on? CPU or something else?
jameslewisuk
Forum Posts: 79
2012/01/30 - 22:57
Setialpha, I think this is the right version of the NetworkLocation.apk as its 113 KB (116,627 bytes) and is the same as the one I got from a Samsung Galaxy Ace phone, and the same file also on my ZTE skate phone which both use the same MSM7227 CPU
Not sure why it doesn't work though? I can see that it's running as I can force close it, but it's not doing anything, theres no data (in the clear cache/data page) for the application, whereas on my ZTE skate theres 16kb of data from the app running.....
Help!
finless
Stanton, Ca
Forum Posts: 604
2012/01/31 - 03:11
Same here, after spending a lot of time with Jim on this, I think something is disabled allowing apps to use the networklocation service.  Why I do not know.  But that APK did not work for me either.  I think we are barking up the wrong tree and when I get some time I am going to work on this more.
Bob
jameslewisuk
Forum Posts: 79
2012/01/31 - 22:50
Bob
Bob, I'd really like to get this working too.  Let me know if you need me to do any testing.
My ZTE skate phone is the same CPU etc as well and it's rooted so might be helpful for making comparisons between working and non-working location devices 🙂
84 Guest(s)
Devices in use: Desktop (79), Phone (3), Tablet (2)
hakhiem
jenom
kfwacky
fer30
culo1
dfrt
