LOSS OF TABLET POWER
stc
2012/03/02 - 20:40
I have just lost all power to my tablet. It has been working fine for the past few days, but I tried to alter the settings so that the text on a downloaded book on an e-reader app would all fit on to the screen.
Unfortunately, I found myself in the screen for rebooting and when I tried to exit this, I lost all power. I cannot switch it on again even if I use the mains adapter power source. Can you please advise what I can do to restore power and get it working again.
I am not very computer literate and had to get someone from the Forum to download the full Android Market for me via Team Viewer. I hope I have not lost this as well.
Thank you anyone who can help me.
Thanks Received: 268
2012/03/03 - 12:22
the problem was solved.
register
Forum Posts: 84
2012/03/04 - 21:28
could you share the solution?
2012/03/05 - 16:44
Depends on each case, on his case was a simple solution, using the reset buton from the back of the arnova, you can tell me your problem and i will try to help you.
sammonsmx
Forum Posts: 36
2012/05/26 - 23:14
I took the tablet out for the afternoon - ran it down to around 20% power.  got home, touched power button and no response.  It has been on charge for 2 hours, still no response.  Tried reset button, tried power and down vol with usb plugged in - no response.  Still dead.  Planniong to leave it to charge overnight and see how it is in the morning - unless anybody has a better idea?
sammonsmx
Forum Posts: 36
2012/05/31 - 22:40
Resolved with a charge and a reset.
47 Guest(s)
Devices in use: Desktop (41), Phone (6)
hoholms
rammaiden
iongeorge411@gmail.com
legrandhommer
mindra
xstouf
