[HELP] BROKEN SCREEN.
daktylus
2012/04/10 - 10:15
Hi everybody.
I've brocked  my lcd screen of mine.
The touch-screen still working.
Do you know where can i buy a screen on internet ?
Thanks Received: 3169
2012/04/10 - 11:43
I haven't seen screens for this model on Ebay Confused
There will probably be good second hand offers for the 7cG2 in the coming weeks, as the G3 models are release in the coming weeks.
Also, if it's of any help, I believe the original manufacturer for the 7cG2 is Foxda in China.
Image Enlarger
Thanks Received: 264
2012/04/10 - 13:04
Yes the original manufacturer is in Shenzhen Archos China Division.
crusti
2012/04/13 - 17:06
My screen is broken too.... :^( but stil usable :^)
I enquired with Arnova, they replied if its under warrenty they would replace it or they would charge 75% of the cost of a new one..... not sure what they would say is the price of a new one as I have seen them for £80 (carphone warehouse altough they never seemed to be in stock) up to £300 on Amazon.
also found a website that would do it for £70 online.
I believe its more than just a piece of glass because the 4 buttons at the bottom.
I have looked on the FOXDA site but did not see any section for repairs, i will try to email them to see if they can sell them, will post how i get on
sammonsmx
Forum Posts: 36
2012/06/05 - 15:12
I have a 7C G2 that appears to have an intact screen, but the device does not work.  I picked it upon ebay for £20.  I've stripped it down and rebuilt it, but I can't seem to get any lights on at all.  I need another device to be able to test which bits are broken (battery, charging circuit, screen or motherboard).  Perhaps I might send you mine, or you send me one with a smashed screen and I'll see if I can build a good one from the two. Let me know here or pm me.  I have another 7C G2 to keep so I'm not bothered if I end up passing this one on.  I'm keen to make the £20 back but that's all.
79 Guest(s)
Devices in use: Desktop (75), Phone (4)
atgyuric
BBonch
crispyduck00
asgard2701
Rob_nl
shadowlabs
Topics: 6028
Members: 261274
