gps problem
sanaldi
Forum Posts: 17
2012/06/25 - 18:43
After i run the navigation program, it is fixed to satellites easily but after a moment it says signal dissappeared. gps icon disappears on the task bar. it does not work until a restart. what can be the problem? after a restart what changes?
Thanks Received: 268
2012/06/25 - 22:06
try a custom a firmware
sanaldi
Forum Posts: 17
2012/06/26 - 14:30
yes it is custom firmware already. but stock rom is more stable at gps
sanaldi
Forum Posts: 17
2012/06/26 - 23:29
it is solved with your rom. it is locked to satellites unless i close the problem. Thank you.
Currently Online: ri9000
74 Guest(s)
2 Guest(s)
Devices in use: Desktop (69), Phone (6)
hamishduke
squal
squalangel
anqilan456
havetoregister
werasler
