Gel or Silicon cover for C7 G2 ?
sammonsmx
Forum Posts: 36
2012/05/26 - 12:27
Anybody found a cover that fits? Plenty of leather folders for 7" tablets but can't find a gelor silicon case.  The Amazon Kindle Fire is a similar size, and there are oplenty of covers on ebay for it.  Anybody got experience of one that fits before I blow the four quid and try one?  I'm thinking silicon might be more flexible than gel, so a couple of mm either way may not matter.
sammonsmx
Forum Posts: 36
2012/05/31 - 22:44
Purchased from ebay silicon cover and case for Kindle fire.  It sort of fits - not really good enough - the silicon is loose in every direction and the case needed hacked before I could access the buttons.  Not a great solution so far.
Thanks Received: 3177
2012/06/02 - 09:03
Thanks for your feedback.
I haven't yet found any gel/silicon case specific to the 7c G2 so far, I'll post here if I find any.
47 Guest(s)
Devices in use: Desktop (41), Phone (6)
hoholms
rammaiden
iongeorge411@gmail.com
legrandhommer
mindra
xstouf
