flash player problem
cirrus
Forum Posts: 37
2012/01/22 - 16:58
just like to add stock browser and flash 10.3 works here on unrooted 10G2.  good luck.
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/01/22 - 17:01
Depends, there are interactive and non-interactive contents. The latter indeed works, but I want the former, too 🙂
@jameslewisuk: nope, can't be installed.
jameslewisuk
Forum Posts: 79
2012/01/22 - 17:29
Thanks Cirrus, yeah they also work on my 10G2, but Flash 10.3 doesn't work on 7c G2 with stock browser, which is why we were trying alternative "stock" browsers 🙂
simondo
Forum Posts: 78
2012/01/22 - 17:33
Doesnt support flash because its armv6 cpu needs to be armv7 you should have looked before buying
finless
Stanton, Ca
Forum Posts: 604
2012/01/22 - 17:41
Well I am using Dolphin browser HD and installed Flash 10.3.  It can play interactive content.  I just went to Airport Madeness and played a round.  Google search airport madness.  It works for me.
Also I had heard that possibly the Flash 10.3 on applib is bad.  I am using the version that came with my 10 G2.
Bob
simondo
Forum Posts: 78
2012/01/22 - 17:44
The 7c g2 cant use flash because it has an armv6 cpu. You need an armv7
simondo
Forum Posts: 78
2012/01/22 - 17:48
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/01/22 - 17:49
Well, non-interactive stuff like YouTube does work. But some games won't. I guess, it's just that flashplayer 11 doesn't like galaxy online II.
finless
Stanton, Ca
Forum Posts: 604
2012/01/22 - 18:30
I cant speak for the 7C but for the 10 G2, etc flash 11 does not work properly.  We are all using 10.3
Bob
jameslewisuk
Forum Posts: 79
2012/01/22 - 18:37
I've tried 10.1, 10.3 and 11.0 and none work with bbc iplayer app on the 7c G2
10.3 does work with iplayer app on my 10 G2 though....
ray
Forum Posts: 27
2012/04/18 - 01:43
Link posted earlier works well with stock browser and bbc. I have the nano mod on my 7c g2. I Have not tried with interactive.
http://db.tt/JiTPoXSl
greath
2012/05/28 - 18:54
tomtom123 said
Hello
I have also the problem with install flash.
Ich install it on internel fals also on SD card but it dosent work.
I install Flash palyer Verion 10.3 from Applibs. that no works.
so i resett my Arnova to default and install flash player 10.2 it doesnt work also, also install 10.2 and update to 10.3.
Ich have also no error massage by intalling. only by work with flash.
All applikation who i need flash player say: No flash install, pls install falsh player.
Ich have a Arnovatech 7c G2
greath
2012/05/28 - 18:57
As another new 7cG2 owner I have exactly the same problem. As one of the main things I want to do is watch BBC Iplayer and it won't download unless I have a flashplayer this is a major problem. Did anyone ever find a solution to this problem?
Thanks Received: 268
50 Guest(s)
Devices in use: Desktop (44), Phone (6)
hoholms
rammaiden
iongeorge411@gmail.com
legrandhommer
mindra
xstouf
