2013/02/24
Hi Globula,
My Arnova 7c G2 recently shut down by itself while I was using an app that I used many times before (I did nothing unusual before like installing something or changing settings).
After managing to turn it on again and resetting it with the small hole in the back, I always get the startup assistant when turning the device on. Another thing is that all the installed apps are gone and it looks like it would have 'factory reset' itself but the files/folder-structures are still there i believe. they are not listed in the app manager but it doesn't show anything regarding internal storage (no account of how much internal storage is available, only the words 'internal storage')...
My question now: do you have a quick fix how i can get the previous state of the tablet (everything back as it was before it shut down by itself) or alternatively, can i just use the factory reset function and NANO CFW is still on there and i can start from scratch (or would that create problems)?
Thanks for your help!
What it comes up in mind at this moment is to use adb to dump the /data (userdata) partition and cache
Reset the tablet to factory state, and reflash the data and cache back
If you reset, you will just return to stock Nano CFW
Currently Online: sadako11
73 Guest(s)
Devices in use: Desktop (69), Phone (5)
mogabi
ryb84
smoky551
KarlAnkho
jasondweller
2256667898
