Can anyone help me with Arnova 7C G2 3G
paulomhalmeida
Forum Posts: 14
2012/04/07 - 18:42
Hi can anyone help me with reset to factory settings, our to recovery my Arnova 7C G2 3G
it don't start android system, and I have no knowledge about that systems...
thanks
Thanks Received: 268
2012/04/07 - 23:48
i can help you
paulomhalmeida
Forum Posts: 14
2012/04/07 - 23:53
What I need to due to reset to factory settings I have try a couple reset hole for 10 seconds / after connect power / after power button - no succes.
after try Reset hole for 10 seconds / power and plus button / power cable - no sucess...
my pc recognized Arnova us external devise but I don't get access to it...
I don't know what to due
2012/04/07 - 23:58
instal team viewer and send me the id and password via private message
paulomhalmeida
Forum Posts: 14
2012/04/08 - 00:01
on my pc?
paulomhalmeida
Forum Posts: 14
2012/04/08 - 00:03
I cannot open my Arnova it is completely dead, start's show the word Arnova and Android and frozen there...
2012/04/08 - 00:08
yes, on your pc
2012/04/08 - 12:06
Solved.
paulomhalmeida
Forum Posts: 14
2012/04/08 - 12:27
yes It is mate, only one question 3G, and wireless not working properly, what can I due?
2012/04/08 - 12:28
what is the problem with them ?
paulomhalmeida
Forum Posts: 14
2012/04/08 - 12:32
they did not register anyway, the 3G don't read the card properly, ends saying that network don't allow to register, and wireless is trying to connect but don,t register on the network... well all of it was working before very poor but working
paulomhalmeida
Forum Posts: 14
2012/04/08 - 12:33
I can see tha setialpha just post the new rom, what you think about that rom?
2012/04/08 - 12:38
can you go to settings/about tablet, and tell me the kernel version
android version
baseband version
build number
mod version.
paulomhalmeida
Forum Posts: 14
2012/04/08 - 12:41
android version
2.3.3
baseband version
fw8918=v0.0.4.3
build number
GINGERBREAD SW:0.0.4.5 HW:0.2 eng.bingo.20110817.155043
mod version.
AN7CG2
2012/04/08 - 12:55
strange, i have the same build but i never had problemes with the wifi (i`m not using the 3g)
Setialphas has not released yet the new version, you can still flash his current version.
49 Guest(s)
Devices in use: Desktop (43), Phone (6)
hoholms
rammaiden
iongeorge411@gmail.com
legrandhommer
mindra
xstouf
