broken screen
pjh1960
Forum Posts: 11
2012/07/08 - 20:02
hi all
          where can i get a new  screen as i have broken mine Cry i live in telford uk
Thanks Received: 268
2012/07/08 - 20:23
contact arnova in this situation
there is no screen in the market for the arnova.
pjh1960
Forum Posts: 11
2012/07/08 - 20:27
o great that means lots of £££££Frown
2012/07/08 - 21:21
there is no other way
you can buy an arnova from ebay, in this way you will get it cheap.
pjh1960
Forum Posts: 11
2012/07/08 - 23:34
sent  arnova email will see how much they wont to fix it Frown
pjh1960
Forum Posts: 11
2012/07/10 - 10:37
it is definitely broken.
had a email back from Arnova they do not do repairs Frown i have looked on ebay but can not find a screen
so if any one knows where i can get one i would be gratefulSmile
2012/07/10 - 11:03
you can not buy the screen, you need to buy an arnova from ebay, take the screen from that one and put it on yours 🙂
pjh1960
Forum Posts: 11
2012/07/10 - 11:06
yea i have looked for none working ones but have not found anyFrown
Thanks Received: 3177
2012/07/10 - 11:10
There may be more choice and the price of second hand Arnova 7c G2 may decrease as the new 7c G3 is being released...
pjh1960
Forum Posts: 11
2012/07/10 - 11:25
yea hope so love this tablet since globula_neagra updated it for me LaughLaugh
will a screen from Archos 7 V2 Home Tablet fit ??
sammonsmx
Forum Posts: 36
2012/07/10 - 11:39
No it will not.  The screen incorporates the 4 buttons and the transparent bit for the camera.  It is much more than just a bit of glass, which you will know if you have disassembled.  The outer glasss and the digitizer are one item.
2 options - You sell me your broken 7CG2, or I sell you a spare screen.  What would be sensible prices?  I think I have a spare screen at home, I'll check tonight.
pjh1960
Forum Posts: 11
2012/07/10 - 11:46
i have not taken it apart so did not know (i am new to tablets as had a pc) let me know what price for the screen
sammonsmx
Forum Posts: 36
2012/07/10 - 11:57
OK I'll check at home to make sure - I think I have a broken one and a good one.  I guess around £20 seems reasonable?  I don't mean to be insulting, but are you OK to disassemble etc?  If not you could send me it and I could fix and return.  I'm not looking to make money, just to cover postage cost if it would help.
pjh1960
Forum Posts: 11
2012/07/10 - 12:04
no insult taken. yes that would help i am in telford area if that helps ? if not send me pm with details and we can sort out details Laugh
57 Guest(s)
2 Guest(s)
Devices in use: Desktop (48), Phone (9)
cimoral
merlin077
nrod
midnight-gr
Pajaro047
trroll171717
