bricked droid.
olavo
2012/04/16 - 15:57
Hi there,
Due to a mistake i've done today my tablet stoped working.
I was changing a folder permission but accidently i changed one system folder permission. i turned off the read write and execute permissions in one system folder and then the tablet stoped working. I tryed to reset the device but now it only shows the Arnova logo and nothing else.
Is there any way to unbrick without flashing?
Can any one help me to unbrick it?
Thanks Received: 268
2012/04/16 - 16:20
Yes, i can help you, please download the fallowing
Android SDK
JAVA SDK
SuperClickOne
WHat i`m gonna do:
1: i will flash the recovery, and then guide you to run the fix permission command from recovery mode
2- if the above method does not work i will factory restore your tablet, that means you will lose all the apps, settings.
All the this will be done via team viewer.
olavo
2012/04/16 - 16:49
thank's globula_neagra
I'll be at home by 18:00 and then i'll pm you ok?
2012/04/16 - 16:51
ok
olavo
2012/04/16 - 19:53
Hi globula_neagra, i've got teamviewer and skype ready
2012/04/16 - 21:55
Solved.
pjh1960
Forum Posts: 11
2012/04/26 - 22:17
fixed mine its great LaughLaughLaugh
45 Guest(s)
Devices in use: Desktop (42), Phone (3)
hoholms
rammaiden
iongeorge411@gmail.com
legrandhommer
mindra
xstouf
