Bootloop after reset the system, need help very urgent!
herpie72
2012/08/11 - 11:50
i have a big problem and I hope someone can help me.
I will sell my Arnova 7c G2 tomorrow.
Yesterday evening I have deinstall my apps and then I want to reset the system in factory settings.
Then the Arnova starts with the Arnova screen and after taht the "android" appears and nothing more.
I can only see the name "android " and sometimes it will switch, but after a second the android appears again.
I seems that is a bootloop.
When I press the reset button, the arnova switched off.
So I need help very soon!
It would be greatful if someone has an idea.
Best regards,
Karsten
Thanks Received: 268
2012/08/11 - 14:17
http://www.arctablet.com/blog/forum/arnova-7c-g2-android-firmware-development/how-to-flash-a-rom-on-arnova-1/
Read this tutorial, get the device in fastboot mode, install the drivers
when the device in fastboot mode, check via cmd if the device is in fastboot mode with the command fastboot devices
then to reset the device to factory state type
fastboot -w
fastboot continue
and your device will boot normally
funky31
2012/09/15 - 01:08
hey guys..can you tell me how i start fastboot on the childpad..cause my daughter get bootloop after she delete some apps in the settings......very cool the tutorial..but i dont know how i get fastboot mode on the childpad..(costum rom from this site is installed)...some trouble cause there is no volume button on the pad..i was very affraid if someone could help me.....
2012/09/15 - 13:50
the chilldpad is a different device and can be unbricked in a different way
read this
http://www.arctablet.com/blog/featured/arnova-childpad-custom-firmware-google-play-root/
Currently Online: ri9000
79 Guest(s)
Devices in use: Desktop (71), Phone (9)
hamishduke
squal
squalangel
anqilan456
havetoregister
werasler
