Arnova 7cG2 congelato
tab7g2ar
2012/07/30 - 22:17
Salve.
Dopo aver ricaricato il dispositivo, ho cercato di accenderlo ma inutilmente. Ho premuto sul tasto di reset, ma compare soltanto la dicitura ARNOVA rimanendo bloccata, per poi spegnarsi automaticamente dopo qualche minuto. Sono veramente disperata. Ho anche contattato via e-mail l'assistenza ARNOVA e, sono in attesa di una loro risposta. Potreste, eventualmente, darmi un consiglio?
Grazie anticipate per una eventuale risposta.Cry
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
2012/07/30 - 22:24
How did you charge it - with a usb cable connected to the pc or to a separate power socket(I just don't know which DC connector the 7c G2 has)? Anyways, before reflashing and taking other steps, I would first elave it charging overnight.
Thanks Received: 268
2012/07/30 - 23:24
these are the steps that you need to fallow to fix your tablet
1: get superoneclick
2: get the tablet in fastboot mode (you will find on the forum how)
3: connect the tablet to the computer
4: install the drivers
5: download java sdk
6: download android sdk and install the esential stuff (first ones, and the last ones, no sdk`s)
7: using fastboot check the if the device in fastboot mode
fastboot devices  (if you get a positive result, it is everything ok, if not, you need to get the tablet in fastboot mode )
fastboot -w (this will reset you tablet to factory settings)
if someone can help him with some direction it will be good, i am off from the internet for 10 days.
Currently Online: ri9000
77 Guest(s)
Devices in use: Desktop (69), Phone (9)
hamishduke
squal
squalangel
anqilan456
havetoregister
werasler
