2012/01/22
Hi, like the look of this device, has anyone tried Navionics Charts on it? Are they on AppsLib? I tried to look, but need to reg a device to get access!
Charts are available on Android Market, and are suppoesed to run on other devices with this cpu. Any feedback would be much appreciated.
thanks
2011/12/10
Yes you can... Check out some posts I spotted over here from a Marine guy getting into Marine apps for tablets.
http://www.freaktab.com/forumdisplay.php?56-Marine-Tablet-Applications
Bob
2011/12/20
I use Navionics marine charts on other Android devices, but have been unable to side load them via the sd card (they're not on appslib).
I think the only way is to load Google apps, using the means set out in this forum; I'll try it when it is more foolproof.
Other than the apps problem (and a few teething problems since solved), I'm extremely happy with the tablet; it's ideal for reading the papers and tech sites on the way to work and keep up with email. One of the youtube apps works well and the mp3 search.
regards
78 Guest(s)
Devices in use: Desktop (71), Phone (6), Tablet (1)
hakhiem
jenom
kfwacky
fer30
culo1
dfrt
