arnova 7c g2 stuck at android logo screen
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/01/15 - 23:10
I found the recovery mode (same problem than you got):
- power on device-
- connect to windows using usb-cable
- press reset-button on the back
- phone looks like it's powered off, but windows will ask for qualcomm-driver (so it is NOT powered off, but in recovery mode)
so... there to get the qualcomm driver USB\VID_05C6&PID_900E?
...maybe some samsung device provides the drivers (wave series also uses qualcomm)?
simondo
Forum Posts: 78
2012/01/16 - 00:30
Hmm i dont think thats a qualcomm thing as these are the only android device ive seen with a reset button.
simondo
Forum Posts: 78
2012/01/16 - 01:08
Thats probablys fastboot youve found which means you can flash with abd.
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/01/16 - 06:10
maybe, but it asks for the driver with that name (super one click tells me) and windows says it wants a driver for qualcomm cdma technologies msm.
Before I can try with fastboot I'd need some update.img and a driver for msm7227... anyone?
Edit: I asked Arnova support right now, whether I need to send the device in, or whether they could deliver the driver and the original update.img (they also provide updates, why not original rom?)... let's wait and see.
tremendo
Forum Posts: 42
2012/01/16 - 12:39
I did this and arnova said... press the reset button with a paper clip! I think i'll be sending mine back .
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/01/16 - 13:43
- power on device-
This is not recovery, this is qualcomm programming mode
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/01/16 - 14:17
So no recovery possible from it?
Well, I just called TeVi (the shop I bought it at), they'll replace the device instantly *phew*.
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/01/16 - 14:18
There is not method for recovey.
I have to take back my Tablet and wait a month 🙁
tremendo
Forum Posts: 42
2012/01/19 - 02:53
if anybody finds his thread.. problem solved: look for setialpha's post on how he unbricked his 7c
ng459
2012/01/20 - 16:12
I did a factory data reset - device dead - eventualy got it  to boot up to lock screen but no slider etc.. so cannot do anything anyone got any ideas
I will attempt to work through setialpha's procedure but  need the usb driver to enable adb and fast tools, does anyone have it ?
Could you pm me with it please.
Currently Online: kkn
80 Guest(s)
Devices in use: Desktop (75), Phone (6)
dnjakabssh
KaanFDS
jackthomas
hakhiem
jenom
kfwacky
