2012/01/14
Hello all
I have an arnova 7c g2 that wont finish booting anymore. not rooted, i just installed some apps.. it ran low on battery, i switched it off, and now it wont finish booting after a full recharge ... it just stays stuck at the android logo screen (which moves... and keeps coming up over and over)
any idea how to unbrick it? I couldnt find anything on the net
I am not sure of the Arnova 7c G2 has a recovery mode and how to activate it, that would help you to reflash the default firmware.
Maybe other A7cG2 users have an idea ?
2012/01/11
cirrus said
i had this prob 2wice with a brand new 10 G2 , plug into ac , use paper clip in reset hole for 15 seconds , hold volume + and on/off button at same time for 15 seconds , leave powered on for 20 mins , it should come back on , ive had it twice on brand new 10 G2. good luck
Hold the paper clip for 15 sec, and let it power on by itself.
2011/12/10
2011/12/10
This is everything I have for the 7CG2.
It has a boot.img and a recovery.img and some other files. Also in the .zip is a .rar file that also has a different boot.img and recovery.img. Hopefully one of them will work for you?
These were 2 different ROM dumps that someone sent me a while back.
http://www.helifreakswag.com/an7cg2.zip
Bob
2012/01/04
finless said
simondo, so the boot.img I provided here did not work?
/blog/forum/arnova-7c-g2/original-rom-backup/#p2949
Bob
yeah it worked. it extracted what it needed but the Recovery.img it created is unusable as the partitions it is getting is getting corrupted during compile.
the error im getting is nothing to do with the boot.img you gave me.
Currently Online: kkn
78 Guest(s)
Devices in use: Desktop (71), Phone (8)
dnjakabssh
KaanFDS
jackthomas
hakhiem
jenom
kfwacky
