Arnova 7c G2 newbie
Thanks Received: 268
2012/06/22 - 14:11
you can back up, from recovery
scoobydoo4444
Forum Posts: 17
2012/06/22 - 22:13
Ive looked and looked in the tablet, but cant find recovery,please explain were it is. Thankyou   Embarassed
2012/06/22 - 22:17
you need to go to settings/about device/system updates
the tablet will reset in recovery mode
to enable recovery mode you need to press for 27 time the volume key minus
or in this order the volume keys plus minus plus
then you should see on the screen back menu enabled
you navigate with the volume button, the selection is done with the search button
70 Guest(s)
Devices in use: Desktop (56), Phone (14)
cimoral
merlin077
nrod
midnight-gr
Pajaro047
trroll171717
