Arnova 7c G2 newbie
scoobydoo4444
Forum Posts: 17
2012/06/12 - 20:25
Hello guys/girls
ive just purchased this model recently, please could someone point me in the right direction regarding what firmware to install into it, with links would be great thanks in advance
Paul
Thanks Received: 268
scoobydoo4444
Forum Posts: 17
2012/06/12 - 23:22
wow, it looks extremely hi tec ,not sure where to start there to be honest.
I will have a go tomorrow and see
thanks
PaulConfused
scoobydoo4444
Forum Posts: 17
2012/06/13 - 21:09
Greetings all Laugh
To globula_neagra,
 Thanks for your reply,please be patient, but would you go through the download installation of any firmware i want or need, these are some of the things i want to use.
1, To use BBC I PLAYER
2,TO use SKYPE
3,To be able to play MOVIES,i looked at your post,BEST VIDEO FORMAT FOR ARNOVA 7c G2, but the link doesnt work.
4,To upgrade my Tablet`s SYSTEM SOFTWARE.To enable it to run properly without crashes.
I look forward to your reply and thank you in advance
Best wishes
Paul
2012/06/13 - 21:28
did you tried any firmware, flashed the custom recovery ?
scoobydoo4444
Forum Posts: 17
2012/06/13 - 22:12
no i havent done anything, i dont know what to do .... sorry Embarassed
2012/06/13 - 22:14
k, you will be the last person that is helped via team viewer
install team viewer
and send me the id and password, via a private message
scoobydoo4444
Forum Posts: 17
2012/06/14 - 23:24
Sorry this is my brothers comp and he wont allow me to use teamviewer.
Im confused as i dont see any options for arnova 7c g2 firmware, the nearest being the 7 g2,is the firmware the same ?
2012/06/15 - 00:05
I did not said not even once that there is any firmware downloadble from arnova`s site, so, from where did you had this idea ?
No, is not the same, don`t download the 7 G2 firmware because it will not work.
Read post number 2, that is the only way to get a custom firmware.
scoobydoo4444
Forum Posts: 17
2012/06/15 - 15:25
I have a big problem, my Arnova wont power up, just a dead black screen, i have left it in the charger for an hour or more and nothing happens.
I have NOT added firmware into it yet. I turned it off in the usual way, i dont understand what is wrong,please help
Regards
Paul
2012/06/15 - 15:38
press the reset button from the back
then connect the tablet to the power source, and start it up
scoobydoo4444
Forum Posts: 17
2012/06/15 - 16:32
Thankyou...way did it do that?
i have been browsing your links in post 2 and i assume i have to download all things to my computer desktop first and then put onto the sdhc card and then into my tablet
thanks again
2012/06/15 - 19:22
you need to put onlu the rom on the sd card
then flash the custom recovery via fastboot, then enter in recovery from your tablet and install the new rom from there.
scoobydoo4444
Forum Posts: 17
2012/06/21 - 21:38
install team viewer
Hello
i have team viewer running if you have time now...... to flash my tablet
thanks
scoobydoo4444
Forum Posts: 17
2012/06/22 - 12:44
Thanks globula_neagra for helping me with this, ive also downloaded the adobe flash and it is working on bbc iplayer.
Can you tell me if i can backup the tablet`s OS ,in case there is a problem
cheers
54 Guest(s)
Devices in use: Desktop (44), Phone (10)
cimoral
merlin077
nrod
midnight-gr
Pajaro047
trroll171717
