2013/03/31
Hi guys i really need some help. I've bought a Arnova 7c g2 from eBay and have tried a few things to get google play working. I'm a a stage now where the apps are showing that they've installed in play but they're not on the tablet. When i try to open market on the tablet i get the force close error. I've tried clearing the cache and data and have also uninstalled and re installed more times than i can remember. The only thing i haven't done is throw the table through the window YET. Can anyone please help before i launch it
2013/03/31
Thanks for the reply, i've tried both of your suggestions with little success. I've gone along the SD card route, creating 3 partitions
1, ./ (file system, fat32, 3.5gb, primary)
2, ./data (ext2, 3.5gb primary)
3, ./cache (ext2, 500mb, primary)
i've put the following in the file system partition
http://downloads.nanolx.org/index.php?dir=7CG2_NanoCFW_rev14
i've powered down the tablet but when i try to power up using pwr & vol- nothing is happening and when i try to power up after i've tried this it wont, i have to reset the tablet before it will power up.
Does anyone have any suggestions where i have gone wrong
Thanks in advance
When you press power and volume key - you will see nothing on the screen, it will be black, if you connect the tablet to pc, you will see the pop-up which is requesting/searching for drivers.
You did not read all the guide.
Have a go also on this, read everything, understand, and then try.
I cannot guide you more, if you really don`t manage, have a read here
http://www.arctablet.com/blog/forum/archos-arnova-general/flashingunbrick-project/
2013/03/31
Well i finally got the fastboot to work after around 3 hours, even so it was fast enough for me to do something wrong. I ran this command first
fastboot -w erase system
instead of
fastboot flash recovery trenano-recovery.img
fastboot flash boot nano-boot.img
now the tablet wont move past the anrova screen and i get the following from oneclick
/data/local/tmp/busybox mount -o ro,remount /system > /data/local/tmp/output 2>&1
export TEMPRANDOM=81716
export PS1=END:$TEMPRANDOM;cat /data/local/tmp/output
END:81716* daemon not running. starting it now on port 5037 *
* daemon started successfully *
- exec '/system/bin/sh' failed: No such file or directory (2) -
export PS1=""
Have i completely broke it or is there hope??
you where suposed to
fastboot -w (resets of all the settings/apps, restores the tablet to factory condition)
NOT
fastboot -w erase system (erases the system partition)
Which erased your system, therefore is nothing to boot from.
Get the tablet back in flashing mode, and flash the tablet with the NO SD version
fastboot flash boot boot.img
fastboot flash system system.img
fastboot flash recovery recovery.img
A tip, use drag and drop to get the file path
2013/03/31
Cant get it into fastboot mode now, when powering on pressing power and volume - i'm not even getting any light where as before they came on for a few seconds, screen is also blank. When i try it without the usb connected it come on but stays on the android screen.
Oh well, i think thats it then. Chalk this one down to experience and move on. Thats the last time i try and do this when its turned midnight LOL
2013/03/31
I had one last go at this and i cant believe i actually did it with a lot of help from globula_neagra but sadly i am having a bit of an issue. I can sign in and use Apps Store either with the app or by usuing the google play website. The issue is when i try and download ANYTHING i'm getting an error telling me i have insufficient space to download. I have an 8gb SD card which is empty but one thing i have noticed after flashing with nano is that i do not have any internal storage space. Can anyone shed some light on this??
Thanks again in advance
2013/03/31
the ext2 img's from here http://downloads.nanolx.org/index.php?dir=7CG2_NanoCFW_rev14
these are the only images i have
38 Guest(s)
Devices in use: Desktop (35), Phone (3)
nkkq98
totypraca
morgotrond
create99
torile
wogoko8553@yubua.com
