Arnova 7c g2 Stuck on Android startup screen.
Related Tags
arben19
2012/10/25 - 16:13
I have bought recently this arnova tablet and after two weeks using , when i tried to startupi stuck on starup screen android sign.
i have tried reset pin hole no result .
I have send an email to arnova support but no reply.
If i want to turnit back to shop i bought in need to go to cratia so im stuck here.
Arben Cena
Prishtina 10000
Kosova.
PS : sorry for my english.EmbarassedEmbarassed
Thanks Received: 3177
2012/10/25 - 16:20
There are similar questions in the Arnova 7c G3 forum, please have a look:
http://www.arctablet.com/blog/forum/arnova-7c-g2-general-questions-software-hardware/
You should be able reflash the tablet yourself using ADB and fastboot, see the guides here:
http://www.arctablet.com/blog/forum/arnova-7c-g2-android-firmware-development/how-to-flash-a-rom-on-arnova-1/
arben19
2012/10/25 - 17:01
I think i now what is the problem
last night i have installed an app and i asked my to reboot and then i didn't work i stuck on android srceen but went i connect
to pc it fails to install the driver
so if i download that driver i be able to enter on arnova device via pc and delet all apps
the driver info :
Driver Information for Qualcomm CDMA Technologies MSM / Hewlett-Packard HP Compaq nc6320 (ES475EA#ACB)
Device Name
Hardware ID
USB\VID_05C6&PID_3100&REV_0000
Compatible IDs:
USB\CLASS_02&SUBCLASS_02&PROT_01
USB\CLASS_02
Version
0,1969-12-31
If some bady sent my alink to download this driver i think it will work.
PS: i have tried 4 hours to install this sdk,adk,fastboot, but is very hard and i cant istallit because i dont understand.YellCryEmbarassedYellCryCryCryCryCryCryCryCryCryCryCryCryCryCryCryCryCryCryCryCryCryCryCryCryCryCryCryCryCryCryCryCryCryCryCryCryCryCryCryCryCry
Thanks Received: 268
2012/10/26 - 13:33
your tablet is in qualcomm download mode
reset the tablet using the hole from the back
connect the tablet to a power source
hold the power button pressed till you see a reaction from the tablet.
Currently Online: Gorael
59 Guest(s)
Devices in use: Desktop (58), Phone (2)
Gorael
WhiteD2125
Bokser
hamishduke
squal
squalangel
