Arctools won't run on my Arnova 7c G2
Thanks Received: 3177
2012/01/26 - 21:58
jameslewisuk said
Whatever I do I still can't get it to connect with servers.... I installed all the APK's manually to system/app
ArcTools version 0.61 update for the Arnova 7cG2 is just out. It's made to work together with setialpha custom firmware http://www.arctablet.com/blog/forum/arnova-7c-g2/nano-cfw-arnova7cg2/#p3779
Latest ArcTools can be downloaded from here: http://www.arctablet.com/blog/wp-content/uploads/2010/12/com.arctablet.arctools.apk or from Appslib in about 10 hours as the update will be pushed tonight.
Android Market install with Arctools on the 7cG2 currently has some problems which I am trying to fix.
ra2000
Forum Posts: 32
2012/01/26 - 22:52
Found it - many thanks !
Can't wait to try it out.
I'm not clear on how to instal setialpha's cfw NanoBoot and NanoSystem img files as it does not make it clear.  Do I just download them to the root directory by USB whilst the tablet is switched on and let it 'find them' automatically ? Or does it need a reboot after copying them into the assumed root directory. Confused
Any help would be really appreciated - many thanks ina advance
2012/01/26 - 22:58
ra2000 said
Fantastic work to update Arctools version 0.61.
Can't wait to try it out but the link provided...
http://arctablet.com/blog/wp-content/uploads/2010/12/com.arctablet.arctools.apk
...... just returns an Error 404 page.
It does work it, just clicked on the link, APK is downloaded.
You can find it on Arctablet Blog homepage, in the right column "Essential tools" section.
ra2000
Forum Posts: 32
2012/01/26 - 23:08
Many thanks !
Can't wait to try it out - above you say it's made to work together with Setialpha's custom firmware - I'm not clear whatt o do with the Nanoboot img file and Nanosystem img file.  Do I just copy both img files to the root directory via USB and let the system find them, or reboot ?  Confused
Any help would be really appreciated.
Many thanks in advance.
2012/01/26 - 23:12
You'll need to install ADB on your computer, put your tablet in fastboot and push the files thru adb on the computer. All the instruction are on Setialpha topic, but I'll probably make a complete tutorial when we have a fully working Market.
handsomejackuk
Forum Posts: 38
2012/01/26 - 23:54
check this out loads of apps on here that work
http://www.freewarelovers.com/android
should keep you busy for a while..
sakings99
2012/08/21 - 22:08
Any update to install market.google over 7c 2g?
Thanks Received: 268
2012/08/21 - 22:25
the only way to install market on the 7c g2 is to use a custom firmware.
56 Guest(s)
Devices in use: Desktop (46), Phone (10)
cimoral
merlin077
nrod
midnight-gr
Pajaro047
trroll171717
